1. tonyr6's Avatar
    I noticed since I got Lollipop on my Nexus 5 that if I do anything with the screen on (brightness is set to 10) the battery drains fast. It is even worse when streaming something in the background. I had 99% battery and was streaming music and just checking a couple of forums and the battery went down 4% in less than 10 minutes.
    I then at 95% battery streamed music on DI at 320kbps MP3 only waking up the screen about 4 times to check the time and my battery drain was normal about 15% in about 2 1/2 hours. I then stopped the stream and updated some apps and downloaded on and opened it at in that time my battery went down 2% all the time while the screen was on.
    I think it is that material design junk that drains the battery while the screen is on. While the screen is off I do get normal battery drain I had with KitKat.
    11-20-2014 03:28 PM
  2. SpookDroid's Avatar
    Have you tried clearing your device's cache? Most users seem to agree that this helps A LOT
    11-20-2014 03:38 PM
  3. tonyr6's Avatar
    Yes I even did a factory reset beforehand. I am finding that clearing the device cache is just a placebo effect. It never makes a difference.
    I am most likely getting normal drain it is just that material design junk I can't turn off and no dark theme seems to drain the battery faster with the screen on.
    11-20-2014 03:41 PM
  4. p3ntyne's Avatar
    Absolutely not! Battery life in Lollipop in better than KitKat, for me at least.
    Try another factory reset, although when setting it up, start from new and only install the necessary trusted apps.
    EDIT: I thought you said it went from 99% to 4% in 10 minutes. I've just calculated, 4% every 10 minutes with the screen on is 4.16 hours SOT. It could be better depending on your brightness and other settings.
    11-20-2014 04:08 PM
  5. tonyr6's Avatar
    Brightness is 10.
    11-20-2014 10:46 PM
  6. tonyr6's Avatar
    This is bull. Just fully charged my Nexus 5 and not even 10 minutes with it off it is down to 98% and yes I did reboot it a hour ago while charge and did a stupid cache partition wipe.
    Edit now down to 97% with no use. I am going to reboot this device 5.0 again.
    11-21-2014 01:13 AM
  7. smallbrains's Avatar
    My nexus 5 has been fine with lollipop until about 20 mins ago. Lost 20% charge in 20 mins. After checking battery status is says I have 3 hours left with 80% charge. Not even using WiFi so very odd.
    tonyr6 likes this.
    11-21-2014 07:48 AM
  8. SpookDroid's Avatar
    From the battery report is there anything that seems out of place? Any app that suddenly shot up to the top?
    11-21-2014 10:41 AM
  9. tonyr6's Avatar
    Yes
    [Battery Drain] [Lollipop] [LRX21O] - UPDATE… | Google Nexus 5 | XDA Forums
    I am not alone. I did disable Google Fit (I did reinable it and then saw massive battery drain) as the XDA forums suggested then I rebooted again with 99% battery and left on battery saver mode over night and my battery is 96%
    11-21-2014 10:52 AM
  10. ACADM's Avatar
    Yeah I've been getting this since the update to L; I've turned the screen brightness all the way down but it hasn't made any difference. The battery just drains away without the screen on so I'm having to charge it throughout the day, and this wasn't a problem on KitKat.
    11-21-2014 05:06 PM
  11. tonyr6's Avatar
    It is back to normal drain now that Fit is disabled.
    11-21-2014 05:30 PM
  12. SpookDroid's Avatar
    So the nearly-useless Google Fit is causing the drain? Wowzies!
    11-25-2014 08:05 AM
  1. Wifi Slow on Galaxy S5 - Strange Problem, Please Help
    By Airman1947 in forum Samsung Galaxy S5
    Last Post: 09-17-2017, 02:58 PM
  2. Strange Battery Usage Stats Lollipop
    By belodion in forum Google Nexus 5
    Last Post: 09-09-2016, 04:52 AM
  3. Can't transfer data from phone with broken screen
    By Elina Filipova in forum Samsung Galaxy S5
    Last Post: 11-20-2014, 11:52 PM
  4. Nook app keeps stopping since Lollipop install. any info on fix?
    By Dennis Scullin in forum Legacy Android & Other OS's
    Last Post: 11-20-2014, 09:02 PM
  5. Replies: 3
    Last Post: 11-20-2014, 05:33 PM
