1. Justin D English's Avatar
    My Android Nextbook ran out of power (Only the third time, so I wouldn't think that is the problem), so I let it charge, but now it is entering the system recovery mode and it won't exit. At the bottom of the screen it displays this message:
    E:Bad bootloader arguments
    "(null)"
    E:unknown volume for path [/udisk/factory_update_param.aml
    E:Can't mount /udisk/factory_update_param.aml
    Would greatly appreciate it if you guys could help me find a solution!
    11-27-2014 11:42 AM
  2. Rukbat's Avatar
    It looks as if the filesystem was damaged. Reflashing the ROM would probably fix it.
    Did letting the battery run down to 0 do it? There's no way to tell, but probably not. But doing that even a few times will have an impact on battery life. Try to recharge it when it's down to no less than 40% for maximum battery life.
    11-27-2014 12:17 PM
  3. LR G's Avatar
    "(null)"
    Maybe it shows that boot animation arguments are missing or corrupt. Maybe the bootloader is damaged.
    02-25-2015 05:28 AM
  1. Replies: 1
    Last Post: 11-28-2014, 01:35 AM
  2. hiding app button, etc. on main tablet screen
    By freedda in forum ASUS MeMO Pad 10
    Last Post: 11-28-2014, 01:33 AM
  3. How do I unlock my Note 4?
    By Janet Margelowsky in forum Samsung Galaxy Note 4
    Last Post: 11-27-2014, 11:26 AM
  4. Why are emails on my phone not removed after sync when deleted on server?
    By dougaldan in forum Legacy Android & Other OS's
    Last Post: 11-27-2014, 10:56 AM
