Disable Annoying Beep sound on Volume change.
Subscriber360
Sony Xperia S (Rooted)
Android Jellybean 4.1.2 Build# 6.2.B.1.96
Can Someone Please Tell me How to disable this Annoying Beep
Sound which play everytime i change Volume...
  • I have searched for the answer on Google & This Forum (No Luck).
  • I have tried to find beep file in "/system/media/audio/ui" (Didn't Find).
  • I have Rooted Device and have "ES FileManager Rooted" Installed. Which work just like "RootManager"
I don't think you can get rid of it...It beeps to show you how loud or soft the volume is.
Sorry, but I think you'll just have to tolerate it...
Wish I could help you more. Good luck! :-)
I found a solution that works on my phone! My problem was specifically when I was using headphones. The beeps would be almost painfully loud while the media sound would be alright.
The solution was to unplug the headphones, turn down the media volume without them and then plug them back in.
I solved this on my S10e by using "Buttons remapper" app (note the 's' on buttons as there are many apps that sound similar). I remapped 'volume +' and 'volume -' but here is the thing, you need to map them to 'ring volume down' not just 'volume down'. Then no beep!
I was worried this might mean hardware button wouldn't work for media any more, however they do but this might be because I also use 'Volume Sync' app, and sync notification and media volume. This is a great app anyway to sync notification sounds and ringtone (why on earth would you want to have to control each separately?).
Abheetha Athukorala
