1. aweyrich's Avatar
    I updated my Tmobile Galaxy Note Edge to Lollipop 5.01 and I'm getting both the battery drain bug (2% drain every 10 mins - wow!) and the overheating issues. Is the only way to fix this is to do a factory default/reset wipe?
    I really rather would not because I have a number of customizations that are hard to put back on the phone including some specific ones from work...but if that is the only way to fix it I will do that...someone who has done the factory reset please advise if it truly did fix the battery problem. (Before I do it)
    05-07-2015 12:56 AM
  2. Shikher Pandey's Avatar
    Hello
    Although I have nexus but you can still try this. Just wait for 5.1 update. Till then , just disable app notifications.You may even remove biggie apps like Facebook , Whatsapp. I would not recommend you to do a factory reset, I don't think factory reset will solve this problem.
    05-07-2015 03:19 AM
  3. gone down south's Avatar
    Try clearing cache in recovery first...
    05-07-2015 03:58 AM
  4. Javier P's Avatar
    Check in your battery stats which apps are using so much battery. Post your screenshots here and we'll try to help you.
    05-07-2015 06:30 AM
  5. aweyrich's Avatar
    Can you tell me how to do that?
    05-07-2015 06:59 PM
  6. aweyrich's Avatar
    Here you go
    Attached Thumbnails How do I fix battery drain issue?-screenshot_2015-05-07-19-00-47.jpg
    05-07-2015 07:01 PM
  7. Javier P's Avatar
    Sorry for the delay. Morning here
    You took the screenshot after 2 hours of use and with the 77% of battery left. It's always better to wait until you have around 30% left to get a more accurate picture. Also try to post the general battery stats with the graph and signal bars and the screen on time.
    The battery used by android and system could be for different reasons. Update settling down, too much syncing, some problems with the location settings, who knows. Switch your location settings off and see if it makes a difference.
    Lots of apps using 1%. Check the syncing settings on them and try to keep them to the minimum that suits your needs.
    As said before wipe the cache partition on recovery, no personal data will be lost. Also, clear cache in settings - storage and reboot your phone.
    05-08-2015 07:58 AM
  8. madankrishna's Avatar
    buy new one and use this battery as stand by
    05-26-2015 07:33 AM
  1. How can I re install voicemail on my Sprint Galaxy 5?
    Last Post: 04-17-2016, 06:57 PM
  2. Game sound issues after 5.1.1
    By cupidtoo in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-07-2015, 11:27 AM
  3. how do i root my galaxy 6
    By J Isenhour in forum Ask a Question
    Last Post: 05-07-2015, 12:34 AM
  4. My Galaxy Mega dose not have signal in the house. Do you know why?
    By AC Question in forum Samsung Galaxy Mega 6.3
    Last Post: 05-07-2015, 12:28 AM
  5. How do I delete photos after they are transferred to the computer?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 05-07-2015, 12:22 AM
