1. Blanche Montgomery's Avatar
    Hello Ever since I uodated to Lollipop when my phone is on, ever few minutes it makes this Bong sound
    How do I get rid of it?
    05-09-2015 01:24 PM
  2. N4Newbie's Avatar
    Where is the phone and what is it doing at the time?
    05-09-2015 03:42 PM
  3. DLK1's Avatar
    You will have to try to narrow it do you might try booting in to safe mode to see if it is from an App you installed or from an installed Google App. Booting into safe mode will disable all installed Apps, then see if it still dose it.
    05-17-2015 10:18 AM
  4. lemontang's Avatar
    Do you have your phone in a case that also hold your bank card (or similar chipped swipe card)? If so try turning off NFC. Mine would make a constant bell sound when ever I woke the phone up or moved the case flap (holding my cards) away from the phone and back again. Was the NFC trying to interact with my bank card.
    06-14-2015 10:18 PM
  1. Unfortunately, Clock has stopped. How do I fix this after my Lollipop install?
    By Planehopr in forum Legacy Android & Other OS's
    Last Post: 01-03-2017, 04:13 AM
  2. Replies: 4
    Last Post: 05-22-2016, 11:33 PM
  3. Any problems updating to Lollipop?
    By Climb14er in forum Samsung Galaxy S4
    Last Post: 05-12-2015, 07:48 AM
  4. Replies: 1
    Last Post: 05-10-2015, 12:39 AM
  5. What is the fluid strip in my Note Edge?
    By rajesh g in forum General Help and How To
    Last Post: 05-09-2015, 12:05 PM
