1. Ridddleman's Avatar
    I Have A Blu Studio 5.0 c HD And I Want to know if i Will be Able to Upgrade my Phone To Lollipop That is Running on kitkat 4.4.2 ?
    06-05-2015 05:21 PM
  2. Ridddleman's Avatar
    Help please
    06-05-2015 05:26 PM
  3. jwt873's Avatar
    Generally, your carrier (the one that provides your mobile service) supplies the upgrades. They usually have to tailor new Android versions to be compatible with their services and devices.
    Go to 'Settings' -> About Device -> Software Updates. Once there, tap on 'Update Now'. If there is an update waiting, it will install. If not, it will tell you that you have the latest version. If so, you'll need to contact your carrier.
    If your phone is rooted, then it gets more complicated... You'll have to find and download the correct version of Lollipop on your own.
    06-05-2015 05:47 PM
  4. Rukbat's Avatar
    Settings/General/About device/Software update. If your carrier has an update for your phone, that's how you get it. (Blu has to write it first, then your carrier has to do their stuff on it. The fact that your carrier has an update for a different phone, or a different carrier has an update for your phone, makes no difference.)
    06-05-2015 05:48 PM
  5. Ridddleman's Avatar
    But I Can Be Sure That I Will get it ?
    06-05-2015 06:29 PM
  1. Why can't I download any apps on my Toshiba Thrive?
    By AC Question in forum Android Apps
    Last Post: 07-06-2015, 09:55 PM
  2. Replies: 1
    Last Post: 06-09-2015, 08:02 AM
  3. How can I get my emails to open in Desktop View?
    By 420benz in forum Samsung Galaxy Note 4
    Last Post: 06-06-2015, 06:52 PM
  4. Why isn't my left earbud working?
    Last Post: 06-05-2015, 05:20 PM
  5. What should I do about my claim?
    Last Post: 06-05-2015, 05:13 PM
