1. K_O's Avatar
    I have the Nexus 5 that was updated to Marshmallow. What I have noticed is that every time I leave the range of my home WiFi Network that when I return the phone will not reconnect to the network until I press the power button to activate the screen. Once the screen appears and I enter my PIN the phone quickly connects to the network.
    Anyone else having this problem or know what the deal is?
    Thanks.
    10-21-2015 08:53 AM
  2. B. Diddy's Avatar
    You have the Keep Wi-fi on During Sleep option set to Always, right?
    10-21-2015 01:12 PM
  3. K_O's Avatar
    Yes, that is set to Always but good suggestion in the event it wasn't.
    10-21-2015 01:20 PM
  4. B. Diddy's Avatar
    Darn. Ok, how about a cache partition wipe for good measure? http://forums.androidcentral.com/nex...-recovery.html
    10-21-2015 01:37 PM
  5. AndyPopely's Avatar
    I had the same problem. For me it was fixed by changing my router's DD-WRT wireless settings.
    I changed Wireless Network Mode = Mixed and Wireless Channel Width= Full (20MHz)
    10-21-2015 04:48 PM
  6. R_P_M's Avatar
    Did you solve this Problem?
    I Had the same (and some other anoying bugs after upgrading to marshmellow), even factory reset was useless.
    Yesterday I re-installed Lollipop, now it works again.
    R.
    01-04-2016 10:44 AM
  1. How to restore wifi conectivity - Acer Iconia A3 A10
    By zeteutao in forum Ask a Question
    Last Post: 10-22-2015, 12:04 PM
  2. LG G3 or Nexus 5x..which one to buy?
    By donutss in forum Nexus 5X
    Last Post: 10-21-2015, 11:12 AM
  3. looking for latest AT&T update released on Sept 29, 2015
    By hsk1610 in forum LG Optimus G Pro
    Last Post: 10-21-2015, 08:52 AM
  4. Replies: 0
    Last Post: 10-21-2015, 08:15 AM
  5. Is my Emerson 50 inch flat screen TV able to stream from my S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 10-21-2015, 08:10 AM
