1. PhillyRage23's Avatar
    So I've used my hotspot a lot, and all the sudden from the moment I connect my laptop, it is using an absurd amount of data. In the 30 minutes I had it connected, I used 1.4 gigs.
    Now before you say something regarding my laptop, I turned everything off. Just looking at my desktop with a Word doc in the background. I opened my processes and looked at what was running and nothing was running besides the necessary stuff.
    Does anyone have a solution?
    01-16-2016 04:07 AM
  2. N4Newbie's Avatar
    Because laptops are usually turned off when not in use, they typically try to "take care of business" (or, as I call it, "housekeeping") the moment they are turned on. That means your anti-virus checks and starts downloading updates, Windows Update does the same, and many other apps you may have installed get on the bandwagon - everybody is checking for and downloading updates. If you have a printer installed, you can bet it's driver is checking in. Java? Same thing. Adobe apps? Same. Google drive or similar cloud service? It checks to see if your cloud storage has changed and syncs the local folder if necessary. I can go on and on, but hopefully you get the idea.
    And, of course, your laptop could be infected by any number of well-hidden viruses...
    01-16-2016 07:59 AM
  1. How can I mobile hotspot Chromecast to my Android?
    By AC Question in forum Google Chromecast
    Last Post: 02-24-2017, 06:02 AM
  2. Replies: 1
    Last Post: 02-11-2016, 07:41 AM
  3. How to check Mobile Data Usage in P8 Lite
    By Zillur Rehman in forum Huawei P8 lite
    Last Post: 02-07-2016, 08:10 AM
  4. Battery Life for Gear S2 3G - Bluetooth vs. Mobile Network
    By evlarberryman in forum Samsung Gear S2
    Last Post: 01-19-2016, 12:59 AM
  5. Why can't my galaxy note 4 use wifi?
    Last Post: 01-16-2016, 08:32 PM
