I'm using Android N with Project Fi on a Nexus 6P. I want to use wifi calling at home, so I turn on airplane mode, and then turn wifi back on. This allows me to use wifi calling, but I don't get text messages on either google messenger or hangouts after the phone's been idle for an hour or so. Neither of the messenger or hangouts apps is "battery optimized".
Wondering if anyone else has experienced this, and have found a way to solve it? Or if you haven't experienced this, what are your settings?
I'm mystified why this should be the case. I can bug report it to Google, but I'm just wondering if there isn't some workaround?
Thanks!
Thanks!
