Where is the option to enable portrait landscape mode in settings for Anbdroid M?
I had the icon for Portrait/Landscape mode in the quick settings dropdown, but it disappeared.
Last week, the icon for invert colors disappeared out of blue, but I found the options in settings to enable/disable invert colors and then it appeared again in the quick settings dropdown. It disappeared for no reason, I use it daily.
However, this time I don't know where I could find enalbe/disable screen rotation. I only had it in the quick settings dropdown. This is a crucial option, as I need really need it.
Has anyone experienced disappearing icons from the quick settings drop down?
Thank you.
Re: Where is the option to enable portrait landscape mode in settings for Anbdroid M?
Welcome to the forums. What device do you have? Usually the auto-rotate option is under settings - display.
