1. markm75's Avatar
    We are about to embark on giving our teen a phone.. at least in the wifi sense use at first, maybe phone use soon there after.
    Currently we are on MetroPCS for our regular two lines..
    The phone we will use for them is a Fierce XL smartphone... i think i could also unlock this for other networks, i'd like to find a minute by minute plan where i only add minutes and no data for emergency calls only.. metropcs doesnt appear to have this.
    In terms of android.. what do most people do to lock down the phone.. how do you handle installing apps?
    Im not sure the best plan of action.. ie: i have apps i've paid for already under my account.. i'm thinking when i sign into the phone i should use my email address i have for my other phone/store account ? Then lock the store app down so they cant make further purchases?
    Or do people use a kid email and somehow get the adult purchased apps on after?
    Then in terms of lockdown.. what do most do..
    I saw an app called FamilyTime.. which has good ratings.. i'm assuming i install this even on my phone, then on the teens phone clicking add device and setting lockdown parameters from their phone.. im hoping from my phone in the app i can then view reports and change settings from there..
    Any thoughts and experiences out there?
    Thanks in advance
    07-21-2016 02:21 PM
  2. mhinc's Avatar
    Thanks in advance
    I would not recommend using the active email address you are using on another phone, this would only lead to issues.
    Also you may want to look into setting up a restricted profile on the Android. This link should help you understand what it does and how to do it.
    How to set up parental controls on Android - How-To - PC Advisor
    07-21-2016 10:47 PM
  3. markm75's Avatar
    I had actually seen that article, but i dont think it applies to phones, the setting up of user accounts (marshmallow, etc).
    Without using an active account, that forces everyone to pay multiple times for games/apps does it not? Or do most just login with the primary google store account, use it, install, then remove the account?
    07-22-2016 10:04 AM
  4. anon(632115)'s Avatar
    No it is not just phone related. BTW Marshmallow is a version of Android, not a user account.
    You will need to set up an account on the phone and make sure it is one you have access to and can monitor. You will not be able to use apps purchased on another account that has been removed. If you are concerned about the price of apps you will have to weigh that up against your child's safety.
    mhinc likes this.
    07-22-2016 10:18 AM
  5. markm75's Avatar
    I'm saying in Marshmallow, i dont see the option to add users (no users menu) in the settings (gears).. or maybe i'm just missing something.
    07-22-2016 11:11 AM
  6. anon(632115)'s Avatar
    Ah! Go to settings>accounts, scroll to the bottom and "select "add new"
    07-22-2016 11:28 AM
  7. markm75's Avatar
    Ah yes, i had seen account.. but that just adds new google, or samsung accounts etc, not really a "user profile" per say.. I could always do this on wiping the phone by just using their gmail i have setup already which i monitor i suppose.. not sure how that would differ.. i may still be misunderstanding.
    Is the family time app not worth exploring (in addition)?
    07-22-2016 02:49 PM
  8. gammerthumbs's Avatar
    My wife and I used to use my mobile watchdog. Very nice and displays everything your teen does on their phone. I think it cost $7 per line. But you can block everything and manage everything
    07-22-2016 03:16 PM
  9. anon(632115)'s Avatar
    I don't know about such apps. My son is 31. He keeps an eye on me these days
    07-22-2016 03:52 PM
  10. mhinc's Avatar
    This is how you set it up correctly
    How to Use Android 5’s Restricted User Profiles for Basic Parental Controls
    07-22-2016 09:55 PM
  11. Keith Bryant's Avatar
    @markm75
    I personally using FamilyTime parental control app for last six months and very happy with the performance. I can control my teen's cell phone in much better way. I am enjoying the phone lock, track sms, location history, app blocking, monitor web history and many more features.
    I will recommend you to use FamilyTime app. I already given the positive review about that app on google play.
    Thanks.
    07-25-2016 02:04 AM
  12. Ry's Avatar
    This may sound archaic but any reason to just get a regular (dumb) phone instead?
    Posted via the Android Central App on the Moto X Pure Edition
    07-25-2016 02:12 AM
  13. markm75's Avatar
    I still dont see this anywhere with v6.x.. just accounts.. nothing about restricted profiles.. etc, seems to be a tablet thing, not a phone thing
    07-25-2016 11:21 AM
  14. markm75's Avatar
    @markm75
    Thanks.
    Thanks for that input.. do you also just use generic gmail accounts, not your main one and pay for apps on their phone via that one (twice basically).. i'm thinking i may just put a generic multiple kid gmail account on both phones, pay for their apps via this and lock it down (still paying twice but not 3 times).
    07-25-2016 11:22 AM
  15. markm75's Avatar
    The reason being is we have these phones and will use them as their mini game phones mostly, rather than buying tablets.. with the 9 year old, no need for phone ability just yet, it will be a glorified 5.5" mini tablet.. for the 13 year old, maybe prepaid "emergency" minutes only (unsure how ill do that with metropcs based phone, guessing unlock it and get some 3rd party prepaid minutes that works on it, this being the Fierce XL phone).
    07-25-2016 11:24 AM
  16. mhinc's Avatar
    It's not just a tablet thing. It's a phone thing. I have it on my Galaxy S6 running Marshmallow. Not sure why you are not seeing it, but it's a PHONE thing,
    07-25-2016 09:37 PM
  17. Keith Bryant's Avatar
    @markm75,
    I think you can use same gmail account on both phones. I will advise you to contact their customer support to clear all your confusions. I am very happy with their customer support.
    07-26-2016 02:48 AM
  18. markm75's Avatar
    At least on my s7 edge + marshmallow, its not there, just accounts.. no user profile creation options.
    07-26-2016 12:05 PM
  19. mhinc's Avatar
    Looks like it was removed from Marshmallow
    07-26-2016 11:11 PM
  20. anon(166548)'s Avatar
    Just recently when going in to Play Store on my phone, they have been advertising "Family Library" that allows you to share apps among up to 5 family members. It's still showing up as one of the ads in Play Store (I just looked). You might click on the "Learn more" link and see if that would work for you.
    This is in response to the statement that you would have to buy another set of apps for your teenager's account, not in response to the discussion of multiple user accounts.
    08-03-2016 06:52 PM
  21. Gayle Lynn's Avatar
    When I had BlackBerry PRIV (5.1.1) it did have option for Guest and a second account.
    08-04-2016 09:56 AM
  22. markm75's Avatar
    Finally revisiting this, as i need to decide on something asap.. i didnt see this family library in the play store unfortunately?
    Also.. sounds based on reviews, that family time may be a tad on the yearly expensive side for limited ability.. sounds as if if someone deletes a text you cant track it either..
    Basically i want:
    To be able to limit the phone to use youtube kids ONLY.. be able to see any search results/history from the browser or other apps (and filter what sites they can hit).. be able to see ALL texts from apps like textnow (not using cellular in this case just yet, only wifi plus apps)..
    And maybe be able to add apps i've already paid for somehow without fully logging in my existing gmail account (not as critical as most apps will be free).
    My netgear might have some built in parental options from the router standpoint that may help, but that doesnt help when they arent here in the house.. I think microsofts family security had features like this as well, but i dont know that it works on android.
    My idea was, sign in to google with their gmail accounts i've created and go from there.
    12-21-2016 06:16 PM
  23. markm75's Avatar
    https://play.google.com/store/apps/d...mobile.applockHere are the apps i was considering at this point.. i'm not finding much in the way of an app for android phones that is free and also includes blocking of apps and tracking usage/messaging etc..
    Safe Lagoon
    -Has all the standard stuff you would expect, including remote screen viewing
    -premium plan is around $5.00 per month for 15 devices/profiles which is the cheapest i've seen with the this amount of features.
    MMGuardian
    -Similar features but the pricing seems a bit steeper, roughly $8 per month but there are one time family plans that can be had for $139, but those expire after 5 years i think
    Kids Zone is another option but its mainly just an allowed list of apps and games that game be ran, more than anything
    Family Time appears to be free and do many of things I'm looking for, but the reviews are sketchy, often mentioning, doesnt work etc.
    Kids Place was another free one but it has ads and doesnt always block things correctly.
    Applock was the other option, but there were some limitations on this one or issues (forget exactly, i think content restrictions for adult content being one it was lacking).
    Family Time Parental control was of course another consideration, but the price is steep and some of the reviews said there were issues..
    Price wise (if there is no free alternative), it sounds like Safe Lagoon might be the way to go.
    I would think when using the first or second one, i can use my own gmail/google store account and also for extra safety set a pin on purchase attempts, this way i'm using one store account on both phones, further restricted/monitored by using the protection app
    12-23-2016 12:13 PM
  1. How to get Pokemon Go on the Ellipsis 8
    By AC Question in forum Android Games
    Last Post: 07-21-2016, 10:26 PM
  2. Why wont my device let me move apps to SD card?
    By HonestScript in forum Ask a Question
    Last Post: 07-21-2016, 03:39 PM
  3. Replies: 2
    Last Post: 07-21-2016, 02:27 PM
  4. how to change my backup password since I forgot it
    Last Post: 07-21-2016, 02:06 PM
