Why can I not set a microSD card to private for adoptable storage, even through ADB?
Toppingman
I'm attempting to setup adoptable storage for a friend's Samsung Galaxy Tab E (SM-T560NU), and he has the correct version of Android for it (6.0.1). I've enabled dev mode, usb debugging, and connected the device to a PC with ADB.
I'm able to see the removable card both on the Android device and in my Windows file manager. Running ADB, I can list the target disk but the commands don't appear to have any effect:
shell@gtelwifiue:/ $ sm list-disks
disk:179,64
shell@gtelwifiue:/ $ sm set-force-adoptable true
shell@gtelwifiue:/ $ sm partition disk:179,64 private
shell@gtelwifiue:/ $ sm set-force-adoptable false
shell@gtelwifiue:/ $ sm list-volumes all
private mounted null
public:179,65 mounted 7799-1DFE
emulated mounted null
privatemode unmounted null
After this, the microSD card is still listed as portable storage and not as internal storage. I've exhausted any other commands I can think of, would you have any recommendations?
Thanks,
Trigati
650
Samsung disabled adoptable storage on their MM builds. It's only available on the S7 line via jumping through hoops.
nicos18
