1. mikegen79's Avatar
    I just want to be sure wether 4g comes marshmallow version. Thanks
    10-11-2016 05:17 PM
  2. TwitchyPuppy's Avatar
    Yes. The network speed has nothing to do with the OS.
    10-11-2016 05:26 PM
  3. mikegen79's Avatar
    So, you mean if I upgrade from lollipop to marshmallow my phone will not support 4G LTE? @ puppy
    10-11-2016 05:38 PM
  4. bespinct's Avatar
    No, they mean that 4G is a feature of the phone, not the operating system it runs. If it supports 4G with Lollipop, it will support 4G with Marshmallow.
    10-11-2016 05:49 PM
  5. mikegen79's Avatar
    Now, I understand, thank you very much @bespinct. Please, how can 4G work with or be supported by my phone, Lollipop version. ?
    10-11-2016 05:59 PM
  6. bespinct's Avatar
    I have no idea what phone or carrier you have, but if it isn't 4G now, it won't ever be 4G.
    10-11-2016 07:25 PM
  7. mikegen79's Avatar
    Yes, you are right, it's does not with 4G. The name of the phone is infinix hot 2.
    10-12-2016 01:35 AM
  1. What cases fit lg g4 with leather battery cover
    Last Post: 10-12-2016, 04:17 AM
  2. Backup a android zte avid plus phone
    Last Post: 10-11-2016, 04:18 PM
  3. Backup a android zte avid plus phone
