1. abdurw4824's Avatar
    Hello Guys, this is first time I am posting a question on a forum and Android Central Community brings luck for me.
    SCENARIO:
    It is that after the Marshmallow update on my phone, I started losing on the network so I decided to downgrade it. After gathering all of the knowledge from the forums and using personal knowledge (though I am not much GEEK) managed to download the correct firmware and when I began to flash it through Odin, it fails and an error (SW Check Fail Device 5 Binary 1) shows up and software downgrade is failed. Why does it happen? Is my bootloader locked or what?
    This is what shows up in Phone:
    HELP NEEDED! Downgrade S6 Edge T-Mobile to Stock Firmware from Marshmallow..-20170411_162814.jpg
    This is what shows up in Odin:
    HELP NEEDED! Downgrade S6 Edge T-Mobile to Stock Firmware from Marshmallow..-untitled1.png
    04-11-2017 07:38 AM
  2. abdurw4824's Avatar
    No One got a answer?
    04-11-2017 09:21 AM
  3. TGIS's Avatar
    Have you tried unlocking the bootloader?
    04-22-2017 06:46 AM
  4. abdurw4824's Avatar
    How to unlock this bootloader?
    I have OEM Unlocked it through developer options
    04-26-2017 08:58 AM
  1. How to fix issues with SM N920V on t-mobile
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 04-12-2017, 10:21 AM
  2. How to embed a hyperlink in SMS message
    By Mr Mendelli in forum Ask a Question
    Last Post: 04-12-2017, 12:19 AM
  3. How to stop screenshots from saving twice
    By Zeshan Mian in forum Legacy Android & Other OS's
    Last Post: 04-11-2017, 08:57 PM
  4. Can You Escape From Office
    By Knfandroid game in forum Android Games
    Last Post: 04-11-2017, 11:42 AM
  5. How to fix issues with SM N920V on t-mobile
    Last Post: 04-11-2017, 05:52 AM
