1. parker98's Avatar
    When I press the microphone key while on my Russian keyboard and try to speak in Russian, the text that comes out is in English. I don't get what's the problem and would like to be able to speak in Russian while composing a text message while having my hands busy, please help!
    11-06-2017 05:16 PM
  2. SpookDroid's Avatar
    Which service are you using for voice recognition? If THAT is set to English or if it doesn't have any extra languages active, that's probably why.
    Go to your Settings, Language and Input section. There should be an option for either Google Voice Typing or Samsung Voice Input on your On-Screen Keyboard options.
    11-06-2017 05:28 PM
  3. parker98's Avatar
    Google voice typing is permenantly set to automatic. Is that normal?
    11-06-2017 11:26 PM
  4. SpookDroid's Avatar
    That's what I have mine set as as I usually type in English and Spanish. Never had an issue as long as I start with a distinct word in that language (words that are pronounced the same or similarly in both languages, dictation will usually default to English)
    11-07-2017 12:27 AM
  1. Galaxy Note 10.1 2014 Twitter App no working
    Last Post: 12-14-2017, 03:37 PM
  2. Which manual can I use to downgrade Samsung Galaxy S6 Edge?
    By Android Central Question in forum Samsung Galaxy S6 edge
    Last Post: 11-08-2017, 12:18 AM
  3. Why does the camera not work when i turn it to take a selfie
    Last Post: 11-06-2017, 06:54 PM
  4. Headphone mic not working since latest update. How to fix?
    Last Post: 11-06-2017, 04:49 PM
  5. why wont my touch screen work? not even a year old
    Last Post: 11-06-2017, 04:31 PM
