1. Lauren Ally's Avatar
    I have an "off brand" tablet (Apex Model TM785CH) tablet running kitkat 4.4.2. To my knowledge there is no way for me to manually update my tablet from the update center.....I don't even think I have one actually within my tablet. I noticed that the system webviewer is no longer installed or compatible with kitkat. So I can't use apps without them crushing(error message). Is there a way for me to be able to update my tablet with some sort or apk file...or an some sort is webviewer/something similar to it. Or is it time for me to give up on my tablet and move on xD
    12-27-2017 06:01 PM
  2. Rukbat's Avatar
    If you have Play on your tablet, the Google Play Store is the best place to get apps. they're checked for spyware, viruses, malware, etc., and you get the correct version for your device and Android version.
    If you don't have Play, you can always download any .apk file and install it (just find it with your file manager and tap the apk file - it will install the app). But you are taking a small risk that way.
    12-28-2017 02:16 PM
  1. Replies: 9
    Last Post: 01-04-2018, 11:31 PM
  2. When my LG V10 get Android 7?
    Last Post: 12-28-2017, 02:36 PM
  3. Where can i get my hiteker front screen replaced and how much would it cost?
    Last Post: 12-27-2017, 05:30 PM
