1. Samvarshini's Avatar
    I am using Samsung j7 max and my battery has been fine until the recent update. I did a software update on my mobile last month and since then I have experienced more battery drain when idle. The issue is getting worse day by day . I tried factory reset numerous time .. I also dis a cache wipe and it has not helped. Yesterday I charged my mobile and left it idle for 3 hours and 5% had drained. When i checked the battery usage it showed Android Os and Android system had consumed my battery . What can I do ? Please provide solution .
    05-31-2018 12:39 PM
  2. ManiacJoe's Avatar
    How good is the phone signal strength where you are at?
    Does turning off the GPS system help?
    06-01-2018 03:09 AM
  3. Samvarshini's Avatar
    Yeah i read that it's often due to bad signal strength so I removed my SIM card and kept it idle even then I noticed battery drain .. when I check the battery usage with the sim in and in idle it shodd the cell standby has drained only 1% but the Android Os and Android system has drained more.. and yeah i always turn my location service off.. i am totally clueless as to what is happening ☹
    06-01-2018 06:43 AM
  4. Samvarshini's Avatar
    Thanks for the reply btw ☺
    06-01-2018 06:44 AM
  1. Screen goes black after answering
    By kbz1960 in forum Moto Z
    Last Post: 06-16-2018, 10:19 AM
  2. Cheap-ish phone for UK travel?
    By wiseoldman in forum Buyers Guides
    Last Post: 06-02-2018, 10:31 PM
  3. Replies: 1
    Last Post: 06-01-2018, 01:36 AM
  4. How do I get rid of MM Phone notification. Emergency calls only?
    Last Post: 05-31-2018, 04:35 PM
  5. Replies: 1
    Last Post: 05-31-2018, 11:23 AM
