1. swb32cox's Avatar
    When I start to read news articles motog3 stops displaying it and returns to prior screen..
    Maybe 30 seconds time.
    07-25-2018 03:15 PM
  2. SpookDroid's Avatar
    Is it any specific app? If so, it might have an issue with your phone or if you have a battery optimizer it might be killing off the app automatically.
    07-25-2018 03:30 PM
  3. swb32cox's Avatar
    No. it does it if I try to read GOOGLE NEWS, or NY times, or from FB.
    07-25-2018 04:12 PM
  4. SpookDroid's Avatar
    But is this on a browser, on each app...? Does it happen with any other sites/apps?
    07-25-2018 04:32 PM
  5. swb32cox's Avatar
    I was checking out different articles on different sites thru FB, GOOGLE NEWS, NY TIMES APP.
    Very sporadic.
    Some times I can read entire article. Other times I get cut off. NYT cuts me off but then im another article it doesn't.
    Same as others do.
    Google news will show other website news articles and some work ok but others cut me off.
    07-25-2018 06:36 PM
  6. SpookDroid's Avatar
    If you're reading all these in a browser, try checking if your phone isn't overloading and killing the app (some sites might be heavy in animated ads and in some cases, that can cause conflicts and cause an app to use too many resources) If it's happening through the apps themselves, try seeing if they have an option to use the browser instead and see if that helps (some apps use their internal browser to display news/links, not your installed one).
    07-26-2018 10:32 AM
  1. Replies: 34
    Last Post: 02-19-2020, 01:10 PM
  2. Can anyone help me with unknown sources setting?
    By DMarie04 in forum Samsung Galaxy Note 8
    Last Post: 07-25-2018, 07:34 PM
  3. Airtel Sim card deactivated in lg k7lite but working in other mobile why?
    Last Post: 07-25-2018, 03:06 PM
  4. My phone wont download and it has a error code491
    Last Post: 07-25-2018, 02:48 PM
  5. Why won't the IMEI number stick?
    Last Post: 07-25-2018, 01:55 PM
