1. ROBERTO NGWIRA's Avatar
    It's got 3g and LTE options but still uses 2g once I try to change to 3g only it's says no service so am stuck using 2g which is slow how can I fix this problem please help
    10-20-2018 11:52 AM
  2. Rukbat's Avatar
    Check the 4G frequencies the phone can handle, and the 4G frequencies your carrier uses. If there's no math, you can't get 4G, LTE or not. And, since a lot of carriers have taken data off 3G, that might be why you're not getting 3G.
    Or the phone may just have a couple of bad radios.
    10-20-2018 12:06 PM
  3. anon(10181084)'s Avatar
    Also, maybe your area doesn't have 3G/4G coverage.
    10-22-2018 02:32 AM
  1. Front glass cracked on Samsung A8 (SM-A530W) - what needs to be fixed?
    By archerynut in forum General Help and How To
    Last Post: 10-21-2018, 05:22 PM
  2. How to fix "Gallery has stopped" in LG G6?
    Last Post: 10-21-2018, 03:38 PM
  3. Where is the option to turn off screen while still playing game?
    Last Post: 10-20-2018, 12:25 PM
  4. Data roaming works but i cant receive/ make calls or even sms
    Last Post: 10-20-2018, 12:09 PM
  5. Why is my radio app and other system apps gone?
    Last Post: 10-20-2018, 10:43 AM
