1. bratley0's Avatar
    Hello, I already asked this question here and I got told to buy new battery.
    So the problem is when battery is at 39% it fastly decrease to 37% jumps to 20% and jumps to 0%.
    When I bought new battery nothing changed. Any ideas what this can be?
    (I have Samsung Galaxy Core Prime, Android 5.1.1.)
    07-27-2019 05:13 PM
  2. mustang7757's Avatar
    The problem is it's a 5 year old phone , so when you purchased a new battery for it who knows how long it was sitting on the shelf also and probably not any better then your failed one . Battery only have a certain life shelf so this could be the problem your having .
    07-27-2019 05:40 PM
  3. bratley0's Avatar
    Oh, so how do I fount out if the battery is ok? Is there any trusted seller or something like that?
    08-01-2019 04:08 PM
  4. mustang7757's Avatar
    Can take to repair center have then run diagnostic on it.
    08-01-2019 05:01 PM
  1. Pixel 2 XL - No Text Notification when connected to Car
    Last Post: 08-09-2020, 09:01 PM
  2. Replies: 2
    Last Post: 07-27-2019, 11:51 PM
  3. Shall I be able to use Google Lens on a Galaxy A20 - Octacore Android?
    Last Post: 07-27-2019, 04:26 PM
  4. Note 9: How to re-enable Hidden content on lock-screen?
    Last Post: 07-27-2019, 01:34 PM
  5. How to change WhatsApp contacts to surename/forename
    By Android Central Question in forum Android Apps
    Last Post: 07-27-2019, 10:51 AM
