1. AC Question's Avatar
    when i am taking photos with front cam it is so messed and everything is blur.and not
    able to clean and it is under warranty.
    07-20-2015 12:11 AM
  2. mehigh101's Avatar
    It's probably not dust inside the lens,just things on the outer camera. Try with some alcohol and a paper towel or with a very cheap perfume since it has a lot of alcohol on it.
    07-20-2015 06:19 AM
  1. Replies: 15
    Last Post: 02-22-2018, 12:45 AM
  2. How to turn off camera quick access?
    Last Post: 07-20-2015, 05:20 AM
  3. How can I tell if a text was read?
    By Jan6486 in forum Ask a Question
    Last Post: 07-20-2015, 05:14 AM
  4. How do I remove my contact number from messenger app?
    Last Post: 07-20-2015, 12:00 AM
  5. How do you find a saved image on Android phones
    By stephaninewton5@gmail.com in forum Ask a Question
    Last Post: 07-19-2015, 11:12 PM
