1. lucifercdxx's Avatar
    I purchased an 11e off eBay (used) and loved it. Two months later nothing happens when I try to power on. Went through all troubleshooting steps (charged, removed battery and pressed power button).
    I can chalk it up to just being used but don't know if a) it was the way I used it or b) if it's a known flaw with the 11e.
    I'd buy another in a heartbeat if I didn't have to worry about it happening again two months down the road.
    Sent from my LM-X410(FG) using [deletion]
    07-13-2019 07:24 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Is this a laptop? When I put the name into Google, that was all I got for results.
    07-13-2019 07:29 AM
  3. lucifercdxx's Avatar
    Yes, sorry. It's the Chromebook yoga 11e laptop.
    07-13-2019 07:37 AM
  4. belodion's Avatar
    ^ Welcome aboard.
    Please change your signature so as to exclude the link to the Play Store app. It looks like you’re trying to promote the app. I don’t think you are, but in general we delete direct links like that, as I have in your posts above.
    Thx.
    lucifercdxx likes this.
    07-13-2019 07:41 AM
  5. anon(10614692)'s Avatar
    Does it work on mains power?
    07-13-2019 07:52 AM
  6. lucifercdxx's Avatar
    Do you mean plugged in? No.
    07-13-2019 06:28 PM
  7. B. Diddy's Avatar
    I moved this from the Lenovo Android Tablet forum to the Lenovo Chromebook forum.
    I'd guess the battery failed, although it could also be a motherboard issue. Bring it to a repair shop.
    07-14-2019 02:13 AM
  8. lucifercdxx's Avatar
    Thanks. I didn't realize I was in tablet section.
    I paid $100 for it so may not be worth taking it to a repair shop but a replacement battery is about $13. May try that.
    07-14-2019 06:21 AM
  9. anon(10614692)'s Avatar
    07-14-2019 06:24 AM
  10. lucifercdxx's Avatar
    Will try the novo button later. Thanks.
    07-15-2019 07:19 AM
  1. Cant find hdmi cec option on android box 9.0
    By Android Central Question in forum Android TV
    Last Post: 07-31-2019, 01:44 PM
  2. I want to make calls ring while my phone is on vibrate
    Last Post: 07-13-2019, 04:35 PM
  3. Black bars on sides of videos
    By Daste in forum General Help and How To
    Last Post: 07-13-2019, 06:55 AM
  4. Moving a file on Samsung galaxy tab s2
    By Steve Swift in forum Ask a Question
    Last Post: 07-13-2019, 05:02 AM
  5. how to unlock my privacy protection on my cherry mobile j5s?
    Last Post: 07-13-2019, 04:41 AM
