1. gdesmo's Avatar
    I bought a new in the box lg g flex 2 (sprint) off ebay. Two months after using it the screen went blank with only a slim white vertical line across the top. So I could see no usable video. It also started clicking about every 5 second's. Holding the power button would not reset it. Even with holding volume down button. But without video I couldn't tell what was happening. I had to open the case and disconnect the battery. All seems to be well now but I don't have much confidence in re-activating the device as I was unusable until I dis-assembled and unplugged battery and re-connected. Is there another way to hard reset it without removing 13 screws and unplugging the battery?
    One thing I noticed when I opened the case is the was a sticker inside it "not for sale" Thought that was interesting.
    lgls996 rev 1.0
    android 5.1.1
    Thanks for any thoughts...
    09-30-2016 11:08 AM
  2. D13H4RD2L1V3's Avatar
    Hey there.
    I'm afraid that the 3 words "not for sale" meant that you got a device that was previously used as a floor model in a store, so it's been abused to no-end for about a year.
    I don't think LG is able to do anything since it's not an actual retail unit. Sorry to say, but you might have to hunt around for another phone.
    09-30-2016 11:31 AM
  1. no sound on my lg tribute 5
    Last Post: 11-24-2016, 12:47 AM
  2. Replies: 3
    Last Post: 10-09-2016, 10:49 PM
  3. Phone stuck on Lg screen. Won't do anything else.
    Last Post: 10-07-2016, 04:53 AM
  4. lg g5 battery option
    By bucbans in forum LG G5
    Last Post: 10-01-2016, 10:53 AM
  5. lg g5 data connections are not working
    Last Post: 09-30-2016, 02:33 AM
