1. DVJIMATT's Avatar
    This is not my work. All credit goes to Dfuse and Kintwofan
    Okay this could be very dangerous if you don't pay attention
    2nd GO THANK PLAYFULGOD
    I would really watch the video if I were you
    Now let's get to it.
    Has some of you may know it doesn't seem like you can get into download mode on D95920m
    So here is a work around
    1st thing you"ll need to do is download the D95910c zip in the link
    DO IT FROM YOUR COMPUTER
    Then put the zip on your storage
    Then go to the play store and get the Freedom Flex app
    Thank PlayfulGod Rate the app good
    Now before you go any further make sure you have the DFUSE_Stock_D95910c.zip on your storage
    Now install the recovery of choice I used cwm then reboot into recovey
    This is where you can not be stupid you need to pay attention here
    Factory set and then flash the zip the reboot and you'll now be on JellyBean for whatever reason
    DOWNLOAD LINK
    T Mobile D959
    Dev-Host - DFUSE_Stock_D95910c.zip - The Ultimate Free File Hosting / File Sharing Service
    At&t D950
    Dev-Host - DFUSE_Stock_D950att_jb.zip - The Ultimate Free File Hosting / File Sharing Service
    Sprint LS995
    https://copy.com/QyNDfgDF4bNEOmph
    If you want the tap on screen to work after downgrade dial 3845#*959# then settings and update touch firmware and thank Justin
    For At&t dial 3845#*950#
    10-08-2014 10:22 PM
  2. Psythik's Avatar
    Does this work with the latest D95920s update? I foolishly installed it thinking it was Lollipop.
    11-25-2014 03:50 AM
  1. S5 Pictures and video upside down on PC
    By kgh00007 in forum Samsung Galaxy S5
    Last Post: 10-05-2015, 06:42 PM
  2. Replies: 1
    Last Post: 10-08-2014, 11:03 PM
  3. How do I copy my all Notes to the PC?
    Last Post: 10-08-2014, 11:01 PM
  4. Replies: 2
    Last Post: 10-08-2014, 10:44 PM
  5. How do i get rid of the multi home pages??
    Last Post: 10-08-2014, 09:54 PM
