1. Psythik's Avatar
    Phone is LG G Flex running the latest update available from T-Mobile.
    Whenever I use any app that uses the camera or LED flash, App Ops shows the camera as running in every app that has access to the camera permission.
    Force stopping these apps does not work.
    Disallowing the camera permission in every app that requires it (using App Ops) does not work.
    Using an app to disable the camera does not work.
    The only way to stop the camera from constantly running and draining my battery is to reboot my phone after every time it's used. This is *very* annoying; there's gotta be a better workaround.
    I'm hoping someone can help me since I doubt Lollipop is coming to this phone anytime soon, if ever. I do not wish to downgrade to Jellybean, nor root. A custom ROM isn't an option either because I don't want to lose the ability to use my phone's infrared blaster.
    Thank you for your time.
    11-21-2014 06:38 PM
  2. Psythik's Avatar
    Anybody? Please?
    11-25-2014 03:41 AM
  3. Psythik's Avatar
    Nearly a year later and I'm still having the same issue. I stopped using the camera on my phone altogether.
    09-23-2015 02:34 PM
  1. Replies: 5
    Last Post: 12-05-2014, 05:11 PM
  2. What happened to Calendar Reminders in Lollipop
    By Prof Pink11 in forum Ask a Question
    Last Post: 11-26-2014, 04:54 AM
  3. Replies: 3
    Last Post: 11-23-2014, 11:04 AM
  4. Fastest way to get to the Moto steps app?
    By maxdrive10 in forum Moto 360
    Last Post: 11-22-2014, 07:49 AM
  5. LG Optimus G Pro from At&T but used in Canada
    By vannon in forum LG Optimus G Pro
    Last Post: 11-21-2014, 06:05 PM
