Hoegie
Since two days I have the lg g pad and I can confirm the terrible battery life. I have recharged for the third time and still have terrible batterylife...
I have frozen many lg apps running in the background with titanium backup, I use setcpu at 1350mhz, I only have wifi, and brightness at 40%... the result: 1% batteryloss every two minutes
The tablet itself has sometimes little "freezes" for about 1 of 0,5 seconds (as reported in various reviews)
I think there are different versions of the g pad around.
I am wondering what makes gives some devices better batterystamina than others? Is it the battery itself or is it the processor not using all it? s cores? The people with the "good battery": do you have the little hickups as described above?
My serial number is: 310copy0073080 (made in China)
Here is a review in which they ?ve found a problem with the chip not using it? s 4 cores: LG G Pad 8.3: net niet uit de verf - Hardware en prestaties: kan beter - Review - Reviews - Tweakers (you can read it using google translate)
