1. Jay Sacks's Avatar
    All of a sudden my battery is taking 5 hours to charge 10% (average). Shows 70% with 15 hours to full charge and I have been checking. Used multiple chargers and cables with same result.
    Anyone think a reset might help?
    Or is my looks brand new tablet dead?
    01-04-2018 12:55 AM
  2. dDule's Avatar
    Might be a faulty model. Those problems go as Battery problems. If it was old and used, i would say it was the battery myself but it might be the charging port too. If you are still in a warranty, just get it back for check-up.
    01-04-2018 02:00 AM
  3. dDule's Avatar
    But i would try Hard reset in it to see if it would work and if it does, skip the hassle of getting the warranty!
    01-04-2018 02:01 AM
  4. Jay Sacks's Avatar
    Seems holding down the power button and volume down at the same time does some type of reset. Did a Google search and this was recommended for resetting the charging cycle. Seems to have worked.
    01-05-2018 08:49 AM
  1. Run of Laptop and Android Tablet without Battery
    Last Post: 01-04-2018, 12:41 AM
  2. My HTC 530 wont charge
    By LovemyDog12 in forum Ask a Question
    Last Post: 01-03-2018, 11:12 PM
  3. G5 Battery
    By lever2000 in forum LG G5
    Last Post: 01-03-2018, 09:29 PM
  4. Best way to Charge Note 8
    Last Post: 01-03-2018, 09:24 PM
  5. Axon 7 Quick Charge Not Working?
    By Sedp23 in forum Axon 7 & Axon 7 mini
    Last Post: 01-03-2018, 09:05 PM
