1. Inelukia's Avatar
    I have a LG G Pad F2 8.0, I leave my tablet in my bag and use it only a few days a week usually. Last week I pulled it out and it was on and now when I press the power button to shut down or reboot it increases the media volume.
    Is there a software way to reset this back to it's default? I have already tried factory reset, all that did was wipe out my files and profile.
    Or is this a hardware malfunction.
    02-06-2020 08:47 AM
  2. mustang7757's Avatar
    Hi, Welcome !
    Try safe mode if it does the same ?
    02-06-2020 09:57 AM
  3. Inelukia's Avatar
    It came up in recovery mode. the power button continued to act like a volume up button, so I wasn't able to select anything. The only thing I could do was scroll through the options or hold power and volume down to reboot.
    02-06-2020 03:41 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! I moved this from the G Pad 8.3 to the G Pad F2 8.0 forum.
    It sounds like something might have gotten damaged -- perhaps something hit the tablet or applied pressure to it while it was in the bag, such that the pressure you apply to the Power button is somehow being transmitted to the Volume button's contacts? You'd probably have to bring it to a repair shop to diagnose the problem.
    02-06-2020 04:32 PM
  5. Inelukia's Avatar
    Thanks, that's what I was starting to think also when I couldn't do anything in the recovery mode.
    B. Diddy likes this.
    02-06-2020 04:34 PM
  1. Replies: 2
    Last Post: 02-12-2020, 05:37 AM
  2. Andoid OS uses too much power
    By Android Central Question in forum Developers Lounge
    Last Post: 02-07-2020, 03:38 PM
  3. App to take pictures and add an audio description?
    By littlebigman in forum Ask a Question
    Last Post: 02-07-2020, 02:12 PM
  4. 10384 and 10386 apps
    By mianswat in forum OnePlus 6 & 6T
    Last Post: 02-06-2020, 07:04 AM
  5. Push button to Google Home
    Last Post: 02-06-2020, 06:35 AM
