1. TyBec's Avatar
    I just picked up a G Watch and I love it. But I can't get the microphone to pick up anything I say without putting my mouth up to the microphone and yelling. Do I have a defective unit or would there be a setting or app that is conflicting with the watch? Thanks in advance!
    Posted via Android Central App on the Sony Xperia Z2
    12-17-2014 05:38 PM
  2. Rukbat's Avatar
    There's no user setting for mic sensitivity in cellphones. An app could be using the mic, not allowing the app you want using it to do so, but that's a remote possibility. Check the hole where the mic is, and make sure there's no lint or fuzz clogging it.
    PookiePrancer and saichick04 like this.
    12-17-2014 11:03 PM
  3. PookiePrancer's Avatar
    Or the clear protective tape all over the thing. I thought I chipped my brand new G, only to discover that tape, peeling up!
    12-18-2014 04:11 PM
  4. saichick04's Avatar
    I had the same problem for about 3 days. Turns out just as Rukbat said, it was something clogging up the mic! With a very tiny pin and some patience (my partner's patience not mine ) the voice commands works as it should. I will just take it off from now on when I wash my hands and wipe it down if I get any kind of dirt or something on it.
    12-30-2014 01:00 PM
  1. Replies: 5
    Last Post: 11-08-2016, 06:07 PM
  2. In the Play Store, how to filter out In-App Purchase apps?
    By Wil Wells in forum General Help and How To
    Last Post: 05-22-2015, 06:01 PM
  3. Replies: 3
    Last Post: 01-01-2015, 10:53 PM
  4. Disabling the 4G Mobile data prompt?
    By codyd56 in forum LG G3
    Last Post: 12-23-2014, 05:03 PM
  5. Cleaning the BN back
    By csetoue in forum Motorola Droid Turbo
    Last Post: 12-19-2014, 08:18 AM
