1. Jeffrey Porter's Avatar
    I recently bought a lg g watch and getting on average 3 hours which I hate that is not even enough for work. I have read online and was expecting a day and a half which would be great. I have just been charging it 8 times a day so i can just wear it so somebody please help.
    04-27-2015 08:28 PM
  2. ScottMGS's Avatar
    Wild question: How is your cell reception (not data, not wifi) where you are getting bad battery life?
    04-28-2015 01:18 PM
  3. Jeffrey Porter's Avatar
    its just in general i have 4g all the time.
    04-28-2015 03:41 PM
  4. ScottMGS's Avatar
    Okay, my problem probably isn't the same as yours.
    04-28-2015 04:17 PM
  5. anon(3653)'s Avatar
    Most days I end with 80-85%. Do you have you screen set to "always on"? If so that could be a part of the problem.
    04-28-2015 08:45 PM
  6. mr_nobody's Avatar
    You should be able to use always on with the g watch...this isn't moto 360 we're talking about. I would try factory resetting the watch and don't install any wear apps for the first few days, run completely stock. If you are still getting 3 hours, your watch is defective and you should return it.
    ezzzzz and anon(3653) like this.
    04-29-2015 08:54 AM
  1. Prove me wrong, LG G2 is the best phone you can buy today.
    By Araxxis in forum General News & Discussion
    Last Post: 05-21-2015, 07:08 PM
  2. Does this look like normal battery life according to usage?
    By taariq15 in forum Samsung Galaxy Note 4
    Last Post: 04-27-2015, 10:14 PM
  3. Facebook App Font Problems
    Last Post: 04-27-2015, 06:55 PM
  4. Can I get some help with a Google Play services problem?
    Last Post: 04-27-2015, 06:50 PM
  5. Replies: 1
    Last Post: 04-27-2015, 06:05 PM
