There are several things that could be causing that. If you start your swipe from the camera icon on the lockscreen it will take you into the camera. The same goes for the text messaging, etc.
If you swipe from the right edge of the screen it will take you right into the camera.
If you tap on the clock first and then go through the unlock motion it will take you into the clock application.
If your main goal is to just unlock the phone, then place your finger right on the lock when the screen comes on and slide from there.
Hope this helps!
11-13-2013 03:19 PM
