Running into a mega-annoying problem with the headphone jack, need help!
- So, I'm running into an extremely annoying problem with my G2. Just the slightest touch causes my headphone jack to stop sensing properly.
Example: I'll be listening to Google Music and i'll just ever so slightly move my headphone cable near the base of the 3.5mm headphone plug and suddenly the audio will stop as if I have unplugged my headphones. Yet, my headphones are still snapped in and once I press play again, the music continues on as if nothing has happened.
Some times my phone will go from headphones and speaker...headphones and speaker, headphones and speaker. It's as if it doesn't know my headphones are plugged in.
We are talking super light touching here. Any rotation of the plug while connected will cause it to fail. Simply picking up the phone will cause audio to suddenly stop. I'd be willing to bet that by simply blowing on the damn plug would cause it to fail. Hell, even a fart in the plugs direction would probably cause it to fail. That's how light of a touch I'm talking about here. Also, tapping and rotating the headphone plug while it's plugged in would cause Google Voice search to launch. Super weird.
I don't get whats going on. I see know damage in the headphone input...everything looks fine. I've babied this thing since it has arrived. It has been in a case ever since.
My headphones are good because I've tried them on multiple sources. Plugging in different headphones in to my G2 causes the same problems still. I've tried switching ROMs but the same thing still happens.
I'm at a loss here. I need some advice on what to do. Should I just call Verizon and get a replacement phone? Do I need to unroot to do that?
What a pain in the ***.12-04-2013 02:05 AMLike 0 - I've tried
I posted a thread over at reddit.com/r/lgg2 and a couple of people have chimed in with the same exact issue as me. I thought it was much more isolated and rare, but so far some 4 people have said they are experiencing the same issue. However, I can't find anyone saying anything on the popular Android forums. Weird.12-04-2013 02:17 AMLike 0 -
Okay, so here's what I found and it gets more weird. Tapping the sides during Google Music playback doesn't have an effect. Tapping the top and back of the phone doesn't have an effect. HOWEVER, tapping the lower left part of the phone, right to the left of the LG logo causes the problem to occur and what's really weird about it is that Google Now launches. Even when I squeeze that area. Probably because there is a mic next to the headphone jack. I don't know...weird.
EDIT 2: Squeezing it while playing music and tapping the back of my headphone plug doesn't change anything. Still get the same problem. Jack seems to be completely messed up, but I haven't done anything to cause it.
EDIT: So can confirm that squeezing the lower left area to the right of the LG logo causes the problem. Sometimes it launches Google Now. Sometimes squeezing it causes the speaker phone to kick in and I can hear Google Music playing on it. Seems to be the general area of where the problem is coming from. Tapping that area doesn't seem to be nearly as consistent as squeezing it does.12-04-2013 03:21 AMLike 0 -
- I'm having the same problem. I tried cleaning out the lint but it seems to be a hardware problem. Still looking for a solution.12-05-2013 12:44 AMLike 0
- B. DiddySenior AmbassadorGood question. Let me try it out and see.
12-05-2013 01:22 AMLike 0 - Hey I may have a solution that I was having exact same problem as you.. found my solution on LGG2 forum... the solution is that the male plug on my headphone jack was not pushed in far enough... please try it.. push the plug in all the way then just a bit more of a push til you hear a click.. then its in all the way.. solved my problem.01-18-2014 07:54 PMLike 0
- This is not a "wierd" problem because from what I'm hearing it's obvious to me knowing a little about electronics that you have a faulty female headphone connecter. When you have your headphone jack plugged in and wiggle the jack it creates a on/off switching function in the phone that activates or affects any associated phone calling functions or music apps in your case Google music. If I were you I would call up Verizon tell them what the issue is and there is not much trouble shooting they'll be able to walk you through over the phone so if your one year manufacturers is still in effect which I believe it is since the G2 hasn't been out for a year yet right? Or if you have the Verizon protection plan they should be able to ship a replacement G2 super fast. In the past I've actually had a similar issue with my HTC Thunderbolt and they shipped me a replacement the very next day. Don't try and trouble shoot your phone anymore this will just drive you into more and more frustration. Oh, and if you have "rooted" your phone try and put it back to the original stock setting or else Verizon and or LG will detect this not honor you a free replacement G2. Good luck and let us know how it goes.
Sent from my VS980 4G using AC Forums mobile app01-19-2014 10:18 AMLike 0 - 01-22-2014 06:01 PMLike 0
- I used to have the same "problem." Just push in the male piece harder than you think you have too. It will snap in. Trust me. Just try it. Push it in harder. Your male piece will almost be flush with the phone. Try it. Your problem will be solved. Promise
Posted via Android Central App05-07-2014 04:24 PMLike 0 - The headphone jack stopped cooperating on my Droid 1 years ago. I bought a set of Sony bluetooth earbuds and am still using the same today with my G2.
Sony HBHIS800Z Ericsson Bt Headset05-07-2014 04:24 PMLike 0 - Seriously... it's called Bluetooth. I haven't corded in years. And you don't have to pay an outrageous sum. I own a pair called Joggerz that are outstanfing and paid $25 for on Amazon.
Posted via Android Central AppTall Whitemail likes this.05-21-2014 09:51 PMLike 1 - The headphone jack has to be pushed ** ALL THE WAY IN **, (push HARDER than you would think is prudent, until there is a FIRM CLICK.
i.e. so that NONE of the metal part of the headphone jack is showing.
This worked for me. What a relief....I've got my music back.
- Phil05-27-2014 09:12 AMLike 0 - I am having the exact same problem. Exactly as you describe. I have an LG3 new, mint condition, never dropped, and always encased.
The plug is bad, OK Google has been turned off in all places including my Google profile disallows voice search, yet it still comes on when I try to get the plug to work, stopping my music! So frustrating.
My plan is through Fido, it has nothing to do with the provider, its the cell.
I have found no solution yet, and am in the early stages of researching this.
Help?12-07-2015 12:58 PMLike 0 - I know this is an old post. But i have found a 100% fix for this. Mine kept registering my audio cable as a mic input if i even moved it ever so slightly from being parallel to the audio cable, triggering the google voice search app.
Disclaimer: i do not work on cellular devices, i just dont let them defeat me. You should proceed at your own risk with my advice!
What was happening was the cable would move inside the port and lose contact with one of the miniature connectors. The google voice app would pop up and drive me nuts. I mean i was literally swearing at the app cuz it had a female voice, like she could hear me. But she kept just asking what i was saying with no regard to the nasty things i would say back to her. Damn her.
What i did was take a needle (once again... Try at your own risk) i scraped at the connectorcorrosio to remove any corrosion. Being in my pocket, sweating on hot days, good idea to clean the connectors.
Im sure u should be very careful not to touch 2 of them at the same time as it would probably short out your audio port rendering it useless. Maybe causing other damage.
Carefully clean the connectors. Next i bent, ever so slightly upwards, the last connector closest to the opening. Barely moving it. Do not use your full hulk rage to move it.
I plugged my phone in and it did not do it anymore. It was honestly such an orgasmic release of good feelings to defeat this problem. I mean it. It was plaguing my driving/working listening to music. I said so many words that would make my mother blush, and she was a sailor.
All the menu options on google app and voice search settings cannot fix the botched port. Good luck to everyone. Please do not break your phones more. I hope this helps.04-13-2017 07:40 PMLike 0 - I know this is an old post. But i have found a 100% fix for this. Mine kept registering my audio cable as a mic input if i even moved it ever so slightly from being parallel to the audio cable, triggering the google voice search app.
All the menu options on google app and voice search settings cannot fix the botched port. Good luck to everyone. Please do not break your phones more. I hope this helps.07-11-2017 04:36 AMLike 0 - This is not a "wierd" problem because from what I'm hearing it's obvious to me knowing a little about electronics that you have a faulty female headphone connecter. When you have your headphone jack plugged in and wiggle the jack it creates a on/off switching function in the phone that activates or affects any associated phone calling functions or music apps in your case Google music. If I were you I would call up Verizon tell them what the issue is and there is not much trouble shooting they'll be able to walk you through over the phone so if your one year manufacturers is still in effect which I believe it is since the G2 hasn't been out for a year yet right? Or if you have the Verizon protection plan they should be able to ship a replacement G2 super fast. In the past I've actually had a similar issue with my HTC Thunderbolt and they shipped me a replacement the very next day. Don't try and trouble shoot your phone anymore this will just drive you into more and more frustration. Oh, and if you have "rooted" your phone try and put it back to the original stock setting or else Verizon and or LG will detect this not honor you a free replacement G2. Good luck and let us know how it goes.
Sent from my VS980 4G using AC Forums mobile app02-13-2018 01:59 PMLike 0 - Hey! I own an LG Aristo 3. I've had numerous sets of head phones, & ear buds that DO NOT cause this problem. I've found that on the occasions that the headphones / earbuds work, without bringing up the Google listening app, the jack is not shaped like an L. It's only when the jack is shaped like an L that the problem persists.02-13-2018 02:06 PMLike 0
- Forum
- LG Android Phones
- LG G2
Samsung Galaxy S4 running out of storage space!!!
By Ashish Bhupal in forum Samsung Galaxy S4Replies: 35Last Post: 08-10-2016, 05:21 PM -
I'm looking for a phone with good battery life and a great camera....
By cjohn4043 in forum General News & DiscussionReplies: 16Last Post: 12-08-2013, 05:12 PM -
Did anyone try Run In Crowd on their G2?
By heading4tomorrow in forum LG G2Replies: 6Last Post: 12-04-2013, 11:40 PM -
Does using ODIN to flash the stock MD5 and PIT file lock the bootloader?
By kdwisdom in forum Verizon Galaxy Note 2Replies: 10Last Post: 12-04-2013, 11:11 PM -
Samsung Galaxy Note 3 - Desktop Charging Dock With USB 3.0
By Man In Black 805 in forum Samsung Galaxy Note 3Replies: 0Last Post: 12-04-2013, 12:20 AM
