1. florianl's Avatar
    I have some problem withe me storage space
    i have total 10gb space. and used total 4gb+- and its telling me that i have just 400mb available now were 5 gb disappeared
    i check my download folder and its empty.
    pic Related
    12-06-2013 02:04 AM
  2. RobotHeaven's Avatar
    Download System Monitor Lite (by Christian Gollner), then just look at the "storage stats" section because that shows you a breakdown of what's taking up the most space.
    12-06-2013 05:59 AM
  3. thecycleoflife's Avatar
    That is strange, indeed. Your phone's total space should either be 32 GB or 16 GB, depending on which version of the G2 you bought.
    Sent from my VS980 4G using AC Forums mobile app
    12-06-2013 10:29 AM
  4. florianl's Avatar
    ok download the app and its seems that folder that Called Android takes 4gb .is there something that i can delete for this folder?
    the are two folders Inside
    obb/ = 1.8gb
    data/ =1.5gb
    12-06-2013 10:38 AM
  5. florianl's Avatar
    I bought the 16gb version,i asked the man from the store were the 6 gb disappeared for the 16 he told me the 6gb is for the software
    12-06-2013 10:43 AM
  6. RobotHeaven's Avatar
    In the 16GB version there is only 10.XGB available, and in the 32GB version about 26.X(?).
    obb/ = 1.8gb
    data/ =1.5gb
    They'll almost certainly be for games. When you download games you'll find that many of them will ask you if you want to download extra data after you first run it. If you download it, it goes in the Android/data and Android/obb directories.
    That's why it's not showing up in the apps section
    florianl and Kdroid like this.
    12-06-2013 11:46 AM
  1. Samsung Galaxy Note 3 - Action Launcher problem
    By kdflyer in forum Samsung Galaxy Note 3
    Last Post: 12-07-2013, 11:39 AM
  2. Android 4.4.1 also fixes camera problems on the Nexus 4?
    By jinjin12 in forum Google Nexus 4
    Last Post: 12-06-2013, 09:20 PM
  3. Help!! Two annoying problems with my Note 3
    By Armando Castellanos in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 12-06-2013, 10:18 AM
  4. Problem using SkyDrive Android. Any advice/help out there?
    By tomcon in forum General Help and How To
    Last Post: 12-06-2013, 01:10 AM
  5. Android 4.4.1 also fixes camera problems on the Nexus 4?
    By jinjin12 in forum Android 4.4 KitKat
    Last Post: 12-05-2013, 09:28 PM
