1. childproofedcapsonheranswers's Avatar
    Okay, I am desperate for help here. I am getting LOUD popping noises when my phone is plugged into my 2007 Camry Hybrid's AUX connection. I am getting these popping noises via my car's speakers when I press home screen buttons (messaging, voicemail, Spotify, etc.) as well as when I change songs on Spotify or Pandora. It also makes the same terrible noise when I loose connectivity while streaming music and the speakers make the POP sound at times when I reconnect. The funny thing is is that sometimes I hear no pops, and then minutes later the pops are back. I am in pure misery and it makes listening to music in the car via my phone IMPOSSIBLE to endure.
    I took it in to the Sprint dealer and they turned off all button press noises and haptic feedback as well, but that was the on the 14th day I had it. I told them I was not happy with the phone and they suggested I try a different AUX cable. I bought an expensive audiophile cable, and no dice--I still have the terrible popping sound. I had no trouble with my Samsung connected via Boost and since my car and my cable are the same, it clearly is THIS phone or something with Sprint.
    Is anyone else having this issue? I am heading back over to the Sprint store to discuss these concerns yet again and have them look at the phone. I like the phone, but the static I sometimes get on calls and moreover this POPPING are going to drive me mad. Anyone having similar issues? Anyone have any idea on how to stop the popping sound when using an AUX cable in the car? Thanks everyone!
    12-13-2013 04:00 PM
  2. depechemodegurl's Avatar
    Well since an aux cable is basically just a headphone cable have you tried plugging in headphones and seeing if you still have the popping? That would at least let you know that the problem lies in the headphone jack of the phone and also give you a way to prove it to the Sprint guys. Alternatively, do you know anyone who has an aux port in their car that you can plug into and see if you get it. I would also try using their aux cable which rules out your cable being the issue as well. I use Bluetooth to connect to my car so I haven't had any issues with mine but that doesn't mean you don't have a faulty unit. I would just do some more trouble shooting so you are armed with all that when you go into Sprint.
    Rockin my LG G2
    12-13-2013 05:39 PM
  3. Xtremeyouth1's Avatar
    I have this problem also but I just bought a Bluetooth dangle for the Aux jack and I'm gonna try that
    12-14-2013 08:34 PM
  4. btruthnme's Avatar
    I know i had this same problem i messed with it and messed with it. Come to find out i thought the cable was pushed all the way in but wasn't. I pushed it in a little bit harder and no more popping sounds when phone is moved when touching the phone.
    12-16-2013 10:38 AM
  5. RRHMJ23's Avatar
    This is what i did to solve my problem, same cases have holes for the aux cable a tad small making it hard to push them in
    12-16-2013 08:45 PM
  6. slideways's Avatar
    I have this issue as well. It's only been with this phone, used the same AUX cable with my Galaxy 2 and didn't have this issue. I've pushed the cable in as far as it will go as hard as I can, it makes no difference. It's very annoying, but I'm also going to try a BT receiver and see if that makes a difference. Would like the cable to work better though.
    12-17-2013 10:04 AM
  7. Xtremeyouth1's Avatar
    I got my Bluetooth receiver in and the pop is gone.
    12-18-2013 09:11 PM
  8. Jocelyn84's Avatar
    This, I just bought a Sony BM10 for my car from Macmall for $44.99, and the sound is incredible!
    Sent from my LG-LS980 using Tapatalk 2
    12-19-2013 01:49 AM
  9. Jarrog's Avatar
    I had the same problem this week! I found that using an auxiliary cable with brass connectors (found at Target or 5-Below) solved the problem.
    coachpelkey likes this.
    08-18-2014 04:08 PM
  10. pamplemoose5's Avatar
    I've solved the issue. The reason that it makes a pop sound in between songs, is because when power saving mode is on, it is turning off the speaker in between songs. Just turn off "power saving" mode in your settings pull down on your Samsung, and it won't make a pop sound anymore.
    09-24-2014 08:50 PM
  1. Videos capable of streaming to Samsung TV?
    By spasell in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-09-2014, 08:53 PM
  2. Issue with Connectiong to Mobile Network/4G
    By mach1monorail in forum General Help and How To
    Last Post: 12-14-2013, 09:46 PM
  3. Keyboard problem. Please help.
    By Nuuq in forum HTC One M7
    Last Post: 12-14-2013, 09:32 AM
  4. Replies: 12
    Last Post: 12-14-2013, 02:55 AM
  5. odin now crashes when I press start
    By crbdave2000 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 12-13-2013, 06:29 PM
