1. stellaxtine's Avatar
    So I woke up this morning to my LED notification light flashing every color. After clearing the notifications that had accrued over the night and checking my settings, it still doesn't stop. It never did this before and I'm not sure why it's suddenly doing this now. When I have an actual notification, like a text or email, it'll only flash green- like it normally does- but when there aren't any notifications, it just continually flashes rainbows at me. Is this a new thing? I don't want to turn off that light permanently, because I like when it's actually doing its job of notifying me, but now it's just annoying How do I fix this?
    01-24-2014 02:25 AM
  2. Kelly Burby's Avatar
    have you been using some application that makes your LED flash, if yes then uninstall that and try installing a different application that suits your need.
    01-24-2014 03:32 AM
  3. stellaxtine's Avatar
    No, I haven't downloaded any new apps recently
    01-24-2014 11:58 AM
  4. Ed_Grohl's Avatar
    Using Light Flow?
    If so you actually have to go into the app to get the light to stop. Swiping the notification away does not do it.
    01-24-2014 03:17 PM
  5. TNCattleDog's Avatar
    try rebooting your phone.
    David
    01-24-2014 05:10 PM
  6. NickA's Avatar
    Mine did the same exact thing a week or two ago. It was when I woke up like you, and went to unplug it. I cleared notifications and it still flashed. Mine was flashing three different colors. Rebooted and haven't had the issue since.
    No special apps or anything like that wants to do anything to the LED installed.
    01-25-2014 01:49 PM
  7. lingcod777's Avatar
    I had this, or something similar, happen twice when my morning alarm (stock alarm) when off. I hit snooze but it never alarmed again and the LED was flashing through it's range of colors. No new apps other then updates. I haven't had a chance to dig into/repeat it yet.
    Alexandgut likes this.
    01-25-2014 09:45 PM
  8. JJ Jones's Avatar
    Settings, display, tap notification light. Sounds like the led is set to display when the alarm goes off.
    01-25-2014 10:23 PM
  9. Kelly Burby's Avatar
    then, i guess enjoy the different colors !! i don't think it is annoying in fact its wonderful.......
    01-26-2014 11:09 PM
  10. MexeM's Avatar
    I had this problem too... The back button led was blinking also.
    Rebooting only solved temporarily, since the next morning the phone was again blinking as a Christmas tree.
    I figured out the problem was with the alarm/clock app (the front led is set to rainbow blinking on alarms, as is the back led), so I tried deleting the application cache and data and now it seems working again as it should...
    02-19-2014 04:28 AM
  11. sherrylou937's Avatar
    My phone did the same thing and it was driving me crazy. I removed the SIM card and reinstalled and have had no problems. This did happen after I used the USB cord to download photos to my laptop. Not sure if this was the cause or not.
    04-18-2014 11:45 AM
  12. shadowsjc's Avatar
    same thing happened to me. a reboot solved the problem. haven't been able to recreate the issue on command, although it has happened 3-4x over the past couple of months. i do not use a third party alarm app (i only use the built in alarm app)
    04-22-2014 12:36 PM
  13. Lisa Claber's Avatar
    I had this phone set up yesterday and set my alarm for this morning. The green flashing light is definitely the alarm. I've just turned it off and the light has gone.
    05-23-2014 07:32 AM
  14. Ace Of Grenades's Avatar
    i found a solution the will solve the problem permanently
    1.go into your alarm clock and set a new alarm 1min from now
    2.when it rings tap dismiss and done your rainbow led should be gone.
    06-08-2014 08:20 PM
  15. tiffersxP's Avatar
    Oml Thank you! Finally something that works. I tried everything else on mine and it wouldn't stop, but right after I did that, the problem was resolved.
    08-07-2014 01:42 AM
  16. Barb Goss's Avatar
    My phone was blinking a green light...I couldn't figure it out. I pulled the menu down and there I saw that I had deleted 31 contacts (I only want phone contacts not facebook or google) and it wanted me to verify. I did and the light went out. Usually a blinking light of any color means it wants some type of action from you.
    01-14-2015 09:57 PM
  17. Tony Hammond's Avatar
    So I have to do this every day to get this to stop???
    01-21-2015 10:05 AM
  18. Addicted2Bass's Avatar
    I turned off "sync" and my LG Volt stopped its blinking . I hope this helps someone.
    11-30-2018 10:01 PM
  19. B. Diddy's Avatar
    Welcome to Android Central! Thanks for your suggestion, but turning off Sync also means the phone won't refresh for new emails and other important data.
    12-01-2018 01:37 AM
  1. Flash player on LG G Pad
    By dorblayzer in forum LG G Pad 8.3
    Last Post: 08-26-2014, 06:13 PM
  2. LED Notification Light
    By gl12ox05 in forum Droid RAZR MAXX HD
    Last Post: 01-31-2014, 05:11 PM
  3. Flashed a Custom Rom to my device, but can't access my internal sd card.
    By PixelArt56 in forum General Help and How To
    Last Post: 01-25-2014, 08:53 AM
  4. Pictures with flash enabled are darker
    By pappy53 in forum Motorola Droid MAXX
    Last Post: 01-24-2014, 05:44 PM
  5. Flashed A Nightly and My Phone Died of Heat!
    By Luis Jimenez5 in forum HTC One M7
    Last Post: 01-24-2014, 05:00 PM
