03-08-2017 01:38 PM
35 12
tools
  1. Shacota Cloud Carouthers's Avatar
    Internal battery. All I know is that since yesterday my Droid phone says sims detected unknown source? And will not allow me to receive or send messages... somebody plz help me understand why
    12-16-2014 09:30 AM
  2. Pizza34444's Avatar
    All Verizon LTE phones are factory unlocked to use with other carriers. I have two Verizon LG G2 phones (model VS980)� one is on active service with VZW, the other is off service that I just bought on eBay. When using a foreign SIM, in this case a Singapore Simtel SIM, my active phone detects the SIM no problem, shows the Simtel phone nbr etc and the local partner network which is T-Mobile. The other phone however, using the same Simtel SIM gives me an error message: "This SIM card is from an unknown source" and I am unable to proceed with setup and can't even get into settings. Both phones are identical except one is on active service. Has anyone figured how to get around this problem? Thanks in advance.
    Go to settings>more settings>mobile networks> network mode>then select global or gsm because cdma is what's not letting it go away, but there will be an annoying notification but you'll have to deal with it
    12-23-2014 07:47 PM
  3. acejavelin's Avatar
    I've had my Droid max for about 2 years. Yesterday it started , saying sims detected unknown source, and will not allow me to receive or send messages. I have a ent
    It is likely either a bad connection (remove and reinsert the SIM), a bad SIM, or a defective device... If removing and reinserting the SIM followed by a reboot doesn't clear it up, stop by the local VZW corporate store for a replacement SIM, if you have to call support to get a replacement be prepared to factory default the device, they will often make you try it before sending out a new SIM. If all those things fail, it is likely a bad phone.
    If this is NOT a Verizon SIM, then your "Unknown SIM" message is normal... and it is not related to your SMS issue (MMS possibly, but not SMS).
    01-04-2015 03:40 PM
  4. Roberto Peralta's Avatar
    Thank you very much, you was very helpful for me. My problem was solved.
    Thank you one more time.
    03-10-2015 05:31 PM
  5. dK Das's Avatar
    Can you please explain in details how your problem "the sim card is from unknown source" solved.
    03-17-2015 05:12 AM
  6. jenssymichael1988's Avatar
    hello , can somebody help me
    i bought aSAMSUNG note 4 N910v verizon from ebay, im from dominicn republic
    when insert i GSM sim card it ways no sim car from verizon , doesnt catch network signal and when try to search it manually it says ERROR WHILE SEARCHING FOR NETWORK
    07-16-2015 12:12 PM
  7. Andres Ramod's Avatar
    Yours is more easy, simply hold your finger in the notification till it apear a small menu option, open it en select close app, o something like that, and you will get rid of it, but still every time you reboot your phone it will appear again. I tried to do the same thing in my LG G2 but it does not apear the notification icon
    09-29-2015 03:27 PM
  8. aslamnt007's Avatar
    hi bro i have note 3 verizon android 5.0.im trying to use with du network in uae.i cant access 4g n some functions pleas can you help me
    01-03-2016 12:49 AM
  9. saukay1's Avatar
    My says non Verizon sim cad...what can I do to unlock it?
    02-21-2017 03:19 PM
  10. Max Kondryn's Avatar
    When you choose language,push the buttons in that order: wolume up-wolume down-back-menu-home.
    03-08-2017 01:38 PM
35 12
  1. Galaxy S5: Where is Verizon??
    By vladfan in forum Samsung Galaxy S5
    Last Post: 03-25-2014, 06:50 PM
  2. Anybody use a tablet or smartpen for note-taking in meetings??
    By drew4392 in forum General News & Discussion
    Last Post: 03-22-2014, 03:45 PM
  3. Replies: 3
    Last Post: 03-21-2014, 10:47 PM
  4. Replies: 0
    Last Post: 03-21-2014, 09:51 PM
  5. Problem with s-pen
    By Kiwy10 in forum Samsung Galaxy Note
    Last Post: 03-21-2014, 01:41 PM
