So, I usually have great battery life but over the last month or so my battery drain has been awful. On an average day I would finish up with at least more than 60%, but recently my phone has been shutting off due to depleted battery after only 8 hours with my screen brightness at 40% and only 1 hour of screen time! Battery stats show that Google Play Services has been using up to 50% battery.
So I did the usual cache clear and uninstall apps that I've not used but that did not help.
Then an interesting thing happened.... I do an awful lot of texting at work and remembered that I changed from "Thumb Keyboard" to the Google Keyboard based on what I had read in a thread here. I went into my apps and uninstalled the google KB and since doing so, I am back to finishing my day with roughly 60% battery left. Interestingly, today was a busier day than normal so I actually talked on my phone a bit more as well as texted more.
EDIT: Since removing the google keyboard, Google Services is down to 8% battery use.
So, if anyone else is having issues with battery drain, and you are using the google keyboard, try uninstalling it and use another keyboard for a few days and see if it makes a difference.
David
David
