1. James Skinner's Avatar
    Got a D802
    Battery Drains every 1% in 9 minutes when screen is off on HSPA (Good Signal aswell) on Wi-Fi it is every 50 minutes it goes down by 1%.
    Also when I am on the Phone browsing the internet and Facebook it heats up to 38C, is this normal?
    When I had Cyanogenmod it was a lot better, but it kept heating up to 45C doing the same thing (Facebook and Chrome)
    Attached some ScreenshotsLG G2 Android OS battery Drain-screenshot_2014-09-06-14-57-13.jpgLG G2 Android OS battery Drain-screenshot_2014-09-06-14-57-16.jpgLG G2 Android OS battery Drain-screenshot_2014-09-06-14-57-22.jpg
    Please help me
    09-06-2014 10:00 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    Have you received a new update recently? If so, have you tried a reset?
    09-06-2014 10:10 AM
  3. James Skinner's Avatar
    Thanks,
    Had an KitKat update in May and since then I have done 4 factory resets.
    09-06-2014 10:22 AM
  4. acejavelin's Avatar
    Since you have done the factory reset, multiple times, I would try reimaging the phone with the factory KDZ/TOT files, there is too many odd things here... Android should not be holding the phone awake, mobile data radio should not be drawing that amount of power, heat should not build up that much with such simple tasks, etc. And since you were on CM, you have obviously flashed the phone, so I would return to a known, good, stock configuration and see what happens first.
    09-06-2014 12:05 PM
  5. James Skinner's Avatar
    Hi, Yes i have just done that last night and it worked battery drained 2% overnight and battery temp is at 26C idle and reaches about 35C when in use.
    Android OS still uses 5Hrs but i have had 3hrs screen time max brightness and it is still on 27%.
    I think that is good?
    Thanks for help
    acejavelin likes this.
    09-07-2014 12:30 PM
  1. Samsung s4 battery draining a little fast for me
    By Sammy Diab in forum Samsung Galaxy S4
    Last Post: 09-11-2014, 02:15 AM
  2. Does stock android have file manager
    By xperia2995 in forum Legacy Android & Other OS's
    Last Post: 09-08-2014, 01:24 AM
  3. deleting a phone contact, LG E980
    Last Post: 09-06-2014, 02:00 PM
  4. samsung 3 8 inch tab battery drain
    By Richard Porter2 in forum Ask a Question
    Last Post: 09-06-2014, 08:34 AM
  5. Replies: 2
    Last Post: 09-06-2014, 08:30 AM
