LG G2 (verizon) won't connect to Wi-Fi
I have owned this phone for approx. 2 months without problems. Suddently last night, it would not connect to my Wi-Fi at home. Will say it's connected, with "good" signal strength, but will say "no response from internet at (router name)"
I am not the most tech-savvy, but here are some details....
My husband has the same LG G2 and has had no problems. My kindle, laptops, and Ipad connect to my Wi-Fi without problems.
Wi-Fi router has no security, open connection.
Antivirus program installed (avast) and scanned recently with no virus' found.
Updated with the latest software update several weeks ago. No new updates found.
No new apps installed over the last few weeks.
Tried the "airplane mode" trick with no luck.
Tried restarting the phone multiple times.
Tried "forgetting" the network and re-joining.
Have not tried factory reset...hoping to avoid that!
Thanks for your help!
