1. AC Question's Avatar
    Lg g2 headset
    10-21-2015 02:33 PM
  2. EvvLio Games's Avatar
    Phone heats up when the processor is heavily loaded
    10-21-2015 04:08 PM
  3. mbryanr's Avatar
    This started with my Verizon G2 once it received the Lollipop update. What once was a fast loading smooth phone...is now a bad memory of my old Samsung S2.
    10-24-2015 04:19 PM
  4. DragonRider70's Avatar
    Same. My Verizon LG G2 was a fast, smooth phone to use. I rarely had to reboot it, the battery would last on average of 2 days between charges, and was an all around great phone. Then I got the Lollipop upgrade. Since that dreadful day, my phone battery started dying in less than 12 hours, my phone would be hot, the location services stopped working properly, texts would take up to 5 minutes to send, it was horrible. I was ready to smash it with a hammer!
    The only way I found to get around the problem was to disable my Wi-Fi connection. When I was away from work or home, it would constantly search for a Wi-Fi signal, causing the phone to heat up uncomfortably, and to drain the battery super fast. Now I only enable my Wi-Fi if I am at work or home, and only if I'm going to use it for something that will take a lot of data, such as application updates.
    I close all apps when I'm done using them. I also reboot my phone every couple of days to completely clear out anything that might be running in the background, even with all my apps closed. To this day, every time I reboot my phone, it tells me that it is optimizing apps for Android. Now, at least, I can get about 24 hours of battery life out of my once great phone. Counting the days until I can upgrade to a Note 5!
    10-29-2015 03:31 PM
  5. kevinmindenhall1's Avatar
    I had the same problem. I had loaded task killer and battery protectors and learned that the Android system keeps these apps open in the background. I uninstalled the task killer and battery apps and the phone now stays charged for 24 hours if no exceptional use. I recommend uninstalling any apps that kill apps or claim to improve battery usage. Also my phone no longer gets hot as I think these apps were constantly putting demand on the processor.
    11-13-2015 11:01 AM
  1. How can I reboot my Samsung Alpha A3?
    By AC Question in forum Samsung Galaxy Alpha
    Last Post: 11-06-2015, 08:27 PM
  2. Replies: 3
    Last Post: 10-25-2015, 12:33 PM
  3. Replies: 4
    Last Post: 10-21-2015, 08:19 PM
  4. My galaxy s5 has a small crack on the screen
    Last Post: 10-21-2015, 03:17 PM
  5. What phone should I buy in the UK?
    By paradized in forum General Help and How To
    Last Post: 10-21-2015, 03:03 PM
