1. theobserver75's Avatar
    Hi, my phone fell from a table and hit the floor pretty hard. now the screen shows tear and displays colors incorrectly but the digitizer is fine this seems to be lcd issue only. I was thinking i could just buy the lcd replacement from ebay and have it replaced with the digitizer i have. is this a good idea? did someone (anyone) ever try this? need your opinion please.
    02-08-2016 04:40 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If the screen isn't cracked or shattered anywhere, it might be a connection that was jarred loose by the impact. You could try opening the phone up and checking the connections:
    theobserver75 likes this.
    02-09-2016 12:52 AM
  3. theobserver75's Avatar
    hi thanks for your reply, I looked at opening the phone myself but I don't know a thing about phones and I was certain I would end up wrecking it and what I read suggested that this was not an easy repair. The phone looks like this it is much more noticeable the higher the brightness goes and seems to affect white text and colors stretching them across the screen mostlyscreen replacement help-20160209_141029.jpg screen replacement help-20160209_140850.jpg when the brightness is lowered it is less noticeable but it eventually opaques. Also some images seem to be blinking fast like if a lamp was broken do you think it could be a loose connection?
    02-09-2016 03:21 PM
  4. Rukbat's Avatar
    It appears to be a broken LCD layer. That comes complete with the LED layer and the digitizer. Replacing the digitizer from the original screen requires removing it from the original screen intact. The labor for that would probably be more than the retail price of the phone. (The digitizer is usually removed in small pieces. The glue has to be heated just enough to lt it come off without tearing the screen underneath, and not enough to melt the screen underneath - which is only a few degrees difference. It's almost impossible to get the whole digitizer to that temperature evenly, even with some experience.)
    Having a repair shop replace the screen will probably end up costing a lot less than opening the phone yourself, breaking something, having to fix that, breaking something else, etc., etc. (New techs normally break 5 or 6 screens before replacing a digitizer without breaking anything - on dead phones, of course. Even replacing the whole screen is something they practice a few times before working on a customer's phone.)
    theobserver75 and B. Diddy like this.
    02-09-2016 06:31 PM
  5. theobserver75's Avatar
    Oh I see, I feared that would be it. Yes I read that the screen comes with all the components glued together and disassembling it would be extremely difficult. I will replace the screen entirely. Thank you for your help!
    B. Diddy likes this.
    02-09-2016 09:09 PM
  1. Replies: 2
    Last Post: 04-18-2016, 06:09 PM
  2. Share your Deadpool home screen for one of 50 MERCENARY codes!
    By Ara Wagoner in forum Wallpapers, Ringtones, and Themes
    Last Post: 02-14-2016, 04:13 PM
  3. Samsung S6 Plus Edge totally FAILED! Can you help?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 02-11-2016, 11:08 PM
  4. Please help - Novice with an mxq box that won't work.
    By Richyfar 1974 in forum Ask a Question
    Last Post: 02-09-2016, 01:01 AM
  5. LG OPTIMUS DYNAMIC II Recovery Mode, can I get some help please?
    By David Roberts 2 in forum LG Optimus Series
    Last Post: 02-08-2016, 12:45 PM
