1. qotsa14's Avatar
    I've been using my LG G2 with Cyanogenmod 13.1 for about 2 years now and my wifi just stopped working one day. When i connect to a wifi hotspot it would take until 1-2 minutes for it to turn off and not work again until i shut off my phone, wait a couple a minutes for wifi to work and turn itself off again. Most of the time this doesn't even happen and it just says "mac adress unavaliable". Besides wifi issues my phone also started to work laggy, freezes and shuts itself off on its own sometimes and my battery drains fast.
    I thought the wifi chip could be broken on my phone but then why do i have the other problems? I uninstalled my setup and tried installing 2 different ROMs on my phone but i still have the same issues. So i'm not sure if it's a software issue. If it's a hardware issue i'm having which part could be broken? Is there anyway for me to fix it?
    anon(10181084) likes this.
    12-09-2018 08:41 AM
  2. Rukbat's Avatar
    If the wifi chip is bad, the wifi MAC address won't be available, and the chip may be drawing a lot from the battery. That would also cause slow operation (lag is high internet latency), freezing and shutting off.
    It sounds like it's time for a new phone - fixing this one (a new motherboard) will cost more than replacing it with a newer one.
    12-09-2018 12:12 PM
  3. B. Diddy's Avatar
    I moved this from the General News forum to the G2 Rooting/ROMs forum, for more specific traffic.
    12-09-2018 01:42 PM
  1. Faster battery drain after Dec 5th update
    By Android Central Question in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 12-26-2018, 06:04 AM
  2. Why won't I receive SMS messages on my blu advanced 4.0 phone
    By Derek Haldeman in forum Blu Android Phones
    Last Post: 12-09-2018, 02:22 PM
  3. Front camera did not work
    Last Post: 12-09-2018, 01:54 PM
  4. Faster battery drain after Dec 5th update
    Last Post: 12-09-2018, 07:40 AM
  5. Why Lte not working in Samsung galaxy grand prime SM-G530H????
    Last Post: 12-09-2018, 07:29 AM
