1. Heather Angela's Avatar
    Hi there! Is this g3 beat normally have a low battery life or i just purchased a defected one mine usually stays for just 7 hours if im using data or wifi.
    Or this is normal for all android phones?
    U guys. How many hours does ur g3 beat stays in a day if ur using wifi doing fb and some messengers only? Thanks!
    03-04-2015 06:49 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It would help to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    Heather Angela likes this.
    03-04-2015 09:31 PM
  1. Unexplained battery drain?
    By icmasticc in forum Sony Xperia Z3v
    Last Post: 07-12-2015, 09:06 PM
  2. Awesome battery on my new Galaxy Tab S 10.5!
    By lsmachado in forum Samsung Galaxy Tab S 10.5
    Last Post: 03-04-2015, 07:07 PM
  3. LG best apps made just for g3
    By craig guilder in forum Ask a Question
    Last Post: 03-04-2015, 06:46 PM
