I just ordered one of these this morning. I believe it takes twice as long to charge as the stock battery. I usually plug mine in overnight.
I just got mine in the mail today. It's a little heavier, a little bulkier, but as expected. It came with a screen protector, which I didn't put on. There is also an adapter (basically a piece of plastic with a piece of foam glued on it), so you can use the regular battery with the case. No hole for the speaker, but I did try a speakerphone phone call. I could hear the audio just fine through the holes at the bottom of the case. It said it had about a 62% charge when I first turned the phone on with the new battery. They recommend a 12 hour charge on the first charge, followed by 5 complete discharges/recharges. I thought I would try turning WiFi/Bluetooth/GPS/Sync and forcing my screen on at 100% brightness just to see how long the battery would last for the first few days/charge cycles. It comes with a similar belt holster which reminds me of the Otterbox style, which I rarely used with my SGS3. As far as fitting into a pocket, it probably fits just fine in my back pocket, or my inside jacket pocket, the typical pockets I would use.
So what about normal side pockets?
Putting it in the back pocket isn't an option....it will get sat on.
Guys-
While the Zerolemon battery might be a massive, unsightly accessory, it's an option for those who require extra charge during the day. Again, the beauty of Android is having choices; a failed iPhone experience.
The G3 comes out of the box very sleek, and a 9,000 mAh battery will obviously be larger, I think having the ability to have sufficient charge as a power user is more important than looks.
Remember, Android has always been about options. The Apple crowd has to make due on a battery that historically packed less than 2,000 mAh, and that is simply too restrictive for me.
100%, that's crazy! Nice to know it's not overheating.I actually didn't try putting it in my pocket earlier, as it was still charging it's first charge. It's doable. I'm currently at 6 hours of continuous screen on at 100% brightness and I have 65% battery remaining. I'm more than satisfied with my purchase.
No way.Just saw one on a friend's phone. GINORMUS! LOL. He was getting about 10% dropped calls. I recommended him to go to carrier for new SIM card, and put back the stock battery, to see if this ginormus battery was causing any electrical chatter in the phone.
Let us know how the speaker sounds when you get it. If you notice there is no speaker cut out on the back.
