1. Hamzeh Awadallah's Avatar
    Hi Guys
    this week i notice that my phone only give me 5-7 hours on light to medium use ! my phone still new and i remember when i purchase it was give more that 14 hour on same use and i'm using only WiFi and social app !!!
    10-17-2014 03:25 PM
  2. Gekko's Avatar
    GSam Battery Monitor
    GSam Labs - September 26, 2014
    https://forums.androidcentral.com/e?...token=waovWgBz
    Hamzeh Awadallah likes this.
    10-17-2014 03:28 PM
  3. Hamzeh Awadallah's Avatar
    any help ??
    10-17-2014 06:05 PM
  4. BKHoward's Avatar
    Don't use an SD card and disable VZWAVSService. Those two changes have reduced my Android System usage from the 20-30% range to single digits and increased battery remaining after a 15 hour day from 10-12% to over 30%. The average Battery Life on reported GSam has increased by an hour and is still going up as time passes with these changes in place.
    10-17-2014 07:13 PM
  5. Hamzeh Awadallah's Avatar
    thax for your help bro. but i don't have an sd card because i have 32gb version so it's enough for me
    and what is VZWAVSService. ?? i'm not living in US
    10-17-2014 09:12 PM
  6. Gekko's Avatar
    run the battery app. what does it say?
    10-18-2014 01:04 AM
  7. BKHoward's Avatar
    Sorry, didn't even stop to think about where you live or what cell service you use. VZWAVSService is a preloaded Verizon app that nobody seems to know for sure what it does. Verizon tech support won't even say! Disabling it has had no effect on the phone, however. Disabling it did have a positive effect on my battery life.
    10-18-2014 02:18 PM
  8. Hamzeh Awadallah's Avatar
    10-18-2014 06:52 PM
  9. belodion's Avatar
    ^^^Before we go any further, what was the screen-on time, and at what sort of brightness setting?
    10-18-2014 07:13 PM
  10. Gekko's Avatar
    this action has been known to help battery life - especially after OS updates -
    Clearing the Phone's Cache Partition:
    NOTE: If your phone's performance is low, if the device crashes, freezes etc. then chances are that you're considering applying a factory reset. However, as you might already know, a factory reset will result in the deletion of all personal data stored on the device's internal memory, and it will return the phone's settings to factory values. As such, it's recommended that you first try solving these issues by clearing the phone's cache. By doing so, you won't lose any personal data.
    1. Turn off the smartphone
    2. With the device shut down, press and hold the "Volume Up", "Home" and "Power" keys
    3. After the smartphone vibrates once, release the "Power" key but keep pressing "Volume Up" and "Home"
    4. At the "Android System Recovery" screen, release all hardware buttons
    5. From the recovery menu, press "Volume down" to navigate to and highlight "wipe cache partition"
    6. Press "Power" to select the option
    7. After the cache partition has been wiped, a "Reboot system now" message / option will be highlighted
    8. Press "Power" to reboot your smartphone
    How-to: LG G3: Clear the Cache Partition / App Cache; Reboot in Safe Mode
    10-18-2014 07:44 PM
  11. wazzugrad's Avatar
    So what key is the home key. I only have volume up/down and power for physical keys.
    10-18-2014 07:55 PM
  12. Hamzeh Awadallah's Avatar
    2 hour and screen only 40%
    10-18-2014 07:59 PM
  13. Hamzeh Awadallah's Avatar
    2 hour and screen brightness only 40%
    10-18-2014 08:02 PM
  14. Hamzeh Awadallah's Avatar
    thank you bro. for this help i'll try it and tell you the result
    10-18-2014 08:03 PM
  15. Hamzeh Awadallah's Avatar
    10-19-2014 12:49 PM
  16. belodion's Avatar
    Is that your way of saying you can't wipe the cache partition, Hamzeh? I'm confused about that myself. Some say that you can't do a cache partition wipe on the G3, and others say that you can. LGElectronics in another thread recommended an app cached data wipe to a member who wanted to do a system cached data wipe, so perhaps the latter is not easily done.
    Any members actually done it successfully?
    10-19-2014 02:41 PM
  17. meyerweb#CB's Avatar
    Those instructions are for Samsung phones, which have a physical home button. Whoever wrote that clearly never tried to follow the directions. To boot into recovery on an LG G3, try this:
    How to Enter Recovery Mode on LG G3
    Note that this might not work on Verizon G3's you might have to skip step 3 and 4, and just hold the power buttons down the entire time.
    wazzugrad likes this.
    10-19-2014 02:52 PM
  18. wazzugrad's Avatar
    Thanks, was starting to go crazy thinking I was missing something simple.
    10-19-2014 03:52 PM
  19. maxpayne1256's Avatar
    Did you recently updated your skype app? If yes, then try uninstalling it - I had the same problem.
    10-22-2014 04:48 PM
  1. Will the LG G3 get Android 5.0 Lollipop?
    By Herennow in forum LG G3
    Last Post: 01-21-2015, 11:41 AM
  2. Replies: 3
    Last Post: 10-28-2014, 05:47 PM
  3. LG PC Suite Music artwork
    By Chrisalias in forum LG G3
    Last Post: 10-19-2014, 06:51 PM
  4. Why is nexus 7 recording so choppy?
    By grungedaze in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-19-2014, 11:55 AM
  5. Battery drain?
    By Labhras in forum Samsung Galaxy S4
    Last Post: 10-18-2014, 08:22 PM
