1. paofelix21's Avatar
    i am planning to buy spare batteries for my beloved G3. the main reason is i want to take advantage of the removable battery. anyway i saw one on amazon and ebay. it was caseology and it was cheap. im thinking about buying one. can someone give me a review on caseology batteries? thanks!
    10-21-2014 10:55 AM
  2. worldspy99's Avatar
    Seems to have good reviews on Amazon. Buy it there instead of eBay so that if you don't like it for some reason you can return it. Amazon's policies are a million times better than eBay!
    10-21-2014 11:12 AM
  3. will_solo's Avatar
    I would much rather buy an OEM battery instead of a third party one. Android Central has them for sale as does Amazon. That's what I plan on doing. Probably a little more in price, but OEM gives me piece of mind.
    huntnyc likes this.
    10-21-2014 02:39 PM
  4. paofelix21's Avatar
    ok i think i will buy an OEM. thanks guys!
    10-21-2014 06:15 PM
  5. RumpRoast's Avatar
    I wasn't aware that AC carried them, you can also order them directly from LG for $20
    10-21-2014 07:59 PM
  6. will_solo's Avatar
    Can you post a link to the LG site?
    10-22-2014 08:09 PM
  7. RumpRoast's Avatar
    Will,
    Sorry for taking so long to respond as I was at work. I'm trying to find a link for you. I originally found the link on one of the threads about extended batteries. Mine came shipped from LG for $24 and some change a few weeks ago.
    I'll post up a link once I find it again.
    10-23-2014 11:12 PM
  8. CliveEdinburgh's Avatar
    I bought a cheap Chinese battery. Rubbish, it lasted 3-4 hours. Ended up buying a genuine LG G3 battery. I carry it with me most days. I wouldn't even buy a cheap charger. I care about my 3G.
    10-27-2014 02:22 PM
  9. OTTO002's Avatar
    i believe anker is a good choice and ive been for them for a long time
    http://forums.androidcentral.com/lg-...3-battery.html
    10-27-2014 08:15 PM
  10. clsdv's Avatar
    File a warranty claim. I did with att and received two OEM batteries. I always avoid non OEM they tend to swell and fall apart.
    10-28-2014 02:29 AM
  1. Is there an app to test car battery life?
    By Mark Richards0691 in forum Hardware Hideaway
    Last Post: 02-22-2015, 12:32 AM
  2. Permanent (?) fingerprint on my s5, please help!
    By Milos Radovic in forum Samsung Galaxy S5
    Last Post: 10-26-2014, 04:20 PM
  3. Reading texts over bluetooth- please help.
    By dby2011 in forum Samsung Galaxy S5
    Last Post: 10-21-2014, 07:39 PM
  4. More than just a battery problem?
    By kasyl in forum Google Nexus 4
    Last Post: 10-21-2014, 10:04 AM
  5. Why is my HTC M8 battery draining so fast?
    By Mohnish Karani in forum Hardware Hideaway
    Last Post: 10-21-2014, 07:26 AM
