1. Rico Van Dussen's Avatar
    Just bought this wireless charger from eBay that has 3 coils and works flawlessly!! Thought I share it with ya all! ๐Ÿ˜‰
    Attached Thumbnails Cheap Wireless Charger LGG3 That Works!!-47059.jpg ย  Cheap Wireless Charger LGG3 That Works!!-47058.jpg ย
    belodion likes this.
    11-09-2014 04:13 AM
  2. Wikh's Avatar
    Can you post the link for that?
    11-09-2014 05:46 AM
  3. Rico Van Dussen's Avatar
    Can not post direct link here..
    White version also available in his store!! Search on this description: Qi-Wireless-3-Coil-Transmitter-Charging-Platform-Stand-for-Tablet-PC-Phone-Nokia-
    11-09-2014 06:10 AM
  4. murof's Avatar
    http://rover.ebay.com/rover/1/711-53...02%26alt%3Dweb
    Try that. I found one cheaper than that that appears to be the same charger but it ships from China. This one ships from California and is only $3 or so more.
    11-09-2014 09:15 AM
  5. jshadow's Avatar
    How warm does your phone get? Do you have a battery temperature app? Do you use the charger that came with it?
    11-09-2014 12:18 PM
  6. xocomaox's Avatar
    Replacement back cover?
    11-09-2014 12:29 PM
  7. Rico Van Dussen's Avatar
    Phone does not heat up while charging, and I have European version D855, so charge module included! You got 2 battery's instead... ๐Ÿ˜‰
    11-09-2014 12:51 PM
  8. scgf's Avatar
    I have a couple of circular charging plates like these http://m.ebay.com/itm/141393741652?nav=SEARCH - they work fine with my G3 as long as you find the hot zone which is just below the centre of the phone.
    11-09-2014 01:58 PM
  9. murof's Avatar
    I purchased a replacement back off ebay for $25, but I have read of people buying the sticker version cheaper and applying it inside the stock back themselves.
    I have the Verizon variant with a slim tpu style case and charge it every night. Mine gets warm to the touch but not hot.
    I started using qi with my LG g2 and cannot imagine going back. It's handy to be able to drop my phone in the charger in that dark, not having to worry about fumbling with a plug. It also saves on wear and tear on the micro USB jack.
    Good luck! Hope this helps.
    11-09-2014 02:37 PM
  1. Replies: 19
    Last Post: 11-24-2016, 04:30 AM
  2. Car magnetic mount with wireless charging
    By oshogg in forum For the Car
    Last Post: 08-29-2016, 10:21 PM
  3. Runtastic or Strava - Anyone get these to work on S?
    By terrain in forum Samsung Gear S
    Last Post: 11-12-2014, 06:57 PM
  4. samsung Gear Apps not working
    By enkiki in forum Samsung Gear S
    Last Post: 11-09-2014, 12:07 PM
  5. Front camera doesn't work.
    By Blackfyre in forum HTC One M8
    Last Post: 11-09-2014, 12:16 AM
