1. idon12no's Avatar
    Looking at the battery use section in settings, I noticed that there are entries for Android System and Android OS. Is this reading the same thing twice? Is this normal?
    T-Mobile G3
    11-11-2014 11:55 PM
  2. Murph5150's Avatar
    Good question. I'm not 100% sure, but the OS appears to most influence the CPU. I think the other is active when using features.
    Attached Thumbnails Difference between android system and os?-42197.jpg   Difference between android system and os?-42195.jpg
    idon12no likes this.
    11-12-2014 12:41 AM
  3. apastrophe's Avatar
    T-Mobile G3
    Android OS is that backbone / the middleware between the hardware and the interface you see. Android system includes a variety of packages or simply saying default apps.
    Hence, these two are defined separately
    11-12-2014 04:21 AM
  1. Replies: 42
    Last Post: 03-30-2016, 08:15 AM
  2. Replies: 3
    Last Post: 03-11-2015, 03:10 PM
  3. Most powerful Android phone currently on the Canadian market?
    By Jason Bright in forum General Help and How To
    Last Post: 11-12-2014, 04:24 PM
  4. Replies: 1
    Last Post: 11-11-2014, 11:54 PM
