1. giddyg3's Avatar
    Yet another issue with this phone (sigh).
    Battery went to 0%, plugged in the charger into phone from wall outlet, and I get this screen which I can't power off to get out of: ""Firmware Update: Do not unplug the USB connection until the process is complete."
    11-21-2014 09:50 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Ugh, how new is the phone? Can you get a replacement, either from the store or from LG?
    It sounds like it could be an issue with the USB port or the cable--it thinks it's connected to the computer via USB, rather than a wall outlet. Also thinks it's getting signals about firmware update being sent over USB?
    11-21-2014 12:43 PM
  3. aaabbbds's Avatar
    This happened to me also.
    This happened, when i plugged the phone to computer when it was trying to shut itself down, apparently connecting to charger does the same. AFAIK no firmware update was going on.
    The phone was all dead, except the screen.
    I detached battery and reattached it. It is now working fine.
    11-10-2015 08:26 AM
  4. Kathleen Boots's Avatar
    Thanks that was a fix for me
    07-10-2016 06:27 PM
  5. tootalumfer's Avatar
    take the back off pull battery out then put it back in put the back part back on and it should be good
    05-29-2017 10:16 PM
  1. How to get the KitKat Gallery back on lollipop
    By llanita in forum Legacy Android & Other OS's
    Last Post: 03-15-2015, 08:13 PM
  2. Replies: 4
    Last Post: 11-25-2014, 09:38 AM
  3. Why did my Note 4 sd card and picture gallery crash?
    By Da Mobb1 in forum Samsung Galaxy Note 4
    Last Post: 11-21-2014, 07:40 PM
  4. How do I override the headphone jack to play music via Bluetooth?
    By mbreslow3 in forum General Help and How To
    Last Post: 11-21-2014, 01:08 PM
  5. screen dims erratically
    By karensk in forum Legacy Android & Other OS's
    Last Post: 11-21-2014, 11:14 AM
