1. KittyRIOT's Avatar
    So I've been trying for over an hour to get both of these apps to work and haven't had any luck. All my notifications keep flashing green or not showing up at all. I've read multiple threads to figure out how each of them work and how to set them up and I'm just not having any luck at all. Is there something I could be missing? I'm tired of seeing the green notification light!!!
    11-29-2014 01:26 AM
  2. KittyRIOT's Avatar
    Well, now I've gotten the charging LED to show up with Light Manager. Still no light for incoming texts.
    11-29-2014 01:56 AM
  3. kcalmol's Avatar
    Lightflow works for me, as follows. Enable notification light in settings, but only check the box for downloaded apps. Has been perfect for me with that set-up.
    Technified likes this.
    11-29-2014 09:00 AM
  4. meyerweb#CB's Avatar
    No problems with lightflow here.
    11-29-2014 09:44 PM
  5. psp1232171's Avatar
    Hi need to uncheck and check exactly what you need inside the app and enable LED in the phone settings as well. Working here for the wife, she was getting frustrated also.
    11-29-2014 11:21 PM
  6. psp1232171's Avatar
    Hope that helps.
    11-29-2014 11:21 PM
  7. Technified's Avatar
    I was having the same issues! Thanks for the advice!
    Sent from my Verizon LG G3
    11-30-2014 01:20 PM
  1. SOLVED - Moving app icons from one Apps page to another
    By leerandall in forum Samsung Galaxy Note 4
    Last Post: 04-19-2019, 08:41 PM
  2. am i the first derp to lose my phone?
    By jennifer. in forum Samsung Galaxy Note 4
    Last Post: 11-29-2014, 03:33 AM
  3. Replies: 6
    Last Post: 11-29-2014, 03:19 AM
  4. Revert From Cyangogenmod back to Touchwiz, but S5 version
    By seb646 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 11-28-2014, 11:57 PM
  5. Why is my Nexus 10 charging to 50 then jumps to 100?
    By measeraj in forum Hardware Hideaway
    Last Post: 11-28-2014, 11:41 PM
